I have a shell command that I’d like to be able to run through Google Assistant but the shell_command
domain cannot be exposed. The two ways I can think of to resolve this are:
- Have a script that wraps the shell command and expose that to google. The downside is that it will either require exposing all scripts, or move to a whitelist mode (which, if I understand correctly, will turn all domains to whitelist mode).
- Create an input boolean or a template switch that will run the shell command.
Is there a better solution? Am I missing anything?
