Hi!
I have a Pi I run Home Assistant on, but I’ve found a couple more apps I’d like to run on it at the same time. It’s a 3B, so not too powerful, but I don’t use Home Assistant with a ton of devices, so I think it should be fine.
Specifically, the first thing I’d like to run is this. As I understand, Home Assistant is pretty much just Linux, so I think it should be possible, right?
To install HA on the Pi, I followed the first set of instructions on this page.
Thanks!
