Hi everybody.
Is there any way to retrieve the running automation alias?
I schedule Tado climate operations through automations. I wanted to manage temporary or permanent overrides, without missing scheduling events. This kind of behaviour is natively provided by the Tado cloud services. I just want to mimic them, without the cloud part.
I use an input_boolean to store the override state for each Tado device, and an input_text to store the last scheduled automation that was triggered. When the override ends, I trigger the automation stored in the input_text.
This is intended to be mainly integrated with Google Assistant through HA scripts.
Since the same action has to be integrated in every automation, it would be more elegant (and error prone!) to retrieve the running automation alias through a template call. Is there any way to achieve this?
Thanks a lot for your help.
- alias: climate_bagnobambini_off
hide_entity: true
- platform: time
at: '07:45'
- platform: time
at: '21:00'
- service: input_text.set_value
data_template:
entity_id: input_text.climate_bagnobambini_lasttrigger
value: 'climate_bagnobambini_off'
- condition: state
entity_id: input_boolean.climate_bagnobambini_override
state: 'off'
- service: climate.turn_off
entity_id: climate.tado_bagnobambini
- service: climate.set_hvac_mode
hvac_mode: 'off'
- alias: climate_bagnobambini_restore
hide_entity: true
- platform: state
to: 'off'
- service: automation.trigger
data_template:
entity_id: "automation.{{ states('input_text.climate_bagnobambini_lasttrigger') }}"
