I’m using a few dallas temp sensor that I run with 5V with 4.7 kOhm resistor between it and the data pin.
However, most videos/guides use the 3.3V with 4.7 kOhm resistor between the voltage supply and data pin. It seems that they can operate between 3-5V so is there any risk with running them at 5V instead of 3.3V?
