I want to run the following setup:
- Home Assistant in Docker
- Nginx-Proxy-Manager in Docker to use a custom domain pointing to my homeassistant instance
- Appdaemon in Docker
- HA and Appdaemon are running via the same docker-compose.yaml file
- nginx-proxy-manager is running using a separate docker-compose.yaml file
Everything works fine except the Appdaemon installation. This is the log of the Appdaemon Initialization:
# appdaemon.log
INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
INFO HASS: HASS Plugin Initializing
WARNING HASS: ha_url not found in HASS configuration - module not initialized
INFO HASS: HASS Plugin initialization complete
INFO AppDaemon: Initializing HTTP
INFO AppDaemon: Using 'ws' for event stream
INFO AppDaemon: Starting API
INFO AppDaemon: Starting Admin Interface
INFO AppDaemon: Starting Dashboards
WARNING HASS: Disconnected from Home Assistant, retrying in 5 seconds
INFO AppDaemon: Found 10 active apps
INFO AppDaemon: Found 0 inactive apps
INFO AppDaemon: Found 0 global libraries
INFO AppDaemon: Starting Apps with 10 workers and 10 pins
INFO AppDaemon: Running on port 5050
It seems like Appdaemon can’t connect to Home Assistant. So maybe I got something wrong in my docker compose file. Especially the part setting the HA_URL
and DASH_URL
concerns me. As I’m using nginx-proxy-manager as reverse proxy for some of my containers made it difficult to follow official documentation and example setups.
# docker-compose.yaml
version: '3'
services:
homeassistant:
container_name: homeassistant
image: "ghcr.io/home-assistant/home-assistant:stable"
volumes:
- ./config:/config
- /etc/localtime:/etc/localtime:ro
restart: unless-stopped
privileged: true
networks:
- proxy-manager
environment:
- VIRTUAL_HOST=mydomain.example
- VIRTUAL_PORT=8123
devices:
- /dev/ttyUSB0:/dev/ttyUSB0
appdaemon:
container_name: appdaemon
image: acockburn/appdaemon:latest
environment:
# 172.24.0.3 is the local ip of the ha container inside the proxy-manager network
- HA_URL="https://172.24.0.3:8123"
- TOKEN="${HA_APPDAEMON_KEY:?error}"
- DASH_URL="http://172.24.0.3:5050"
- TZ=Europe/Berlin
ports:
- "5050:5050"
volumes:
- ./config/appdaemon:/conf
networks:
- proxy-manager
depends_on:
- homeassistant
networks:
proxy-manager:
external: true
For the sake of completeness the appdaemon.yaml
file inside the config folder:
# appdaemon.yaml
appdaemon:
latitude: xx.xx
longitude: xx.xx
elevation: xxx
time_zone: Europe/Berlin
plugins:
HASS:
type: hass
http:
url: "http://172.24.0.3:5050"
admin:
api:
hadashboard:
logs:
main_log:
filename: /conf/logs/appdaemon.log
Can anyone spot where I might have made a mistake? Any help is welcome.
