Running HA on cubox
Have dug out an old Cubox i4-Pro and was wondering if anyone had successfully used one of these to run HA or Hass.io?
Have seen a couple of posts suggesting they can but am new to HA so looking for a steer on where to start?
Hoping someone might be able to help, thanks in advance.
Hello, maybe very too late. But I installed Home assistant on a clean cubox i4x4 with armbinan using armbian-config. There is a 3rd party installation menu which installs home assistant in a docker.
I may be even later! I also have an old 4x4… I was under the impression that 8 GB is a little too lean for HA, how did you handle this?
I just installed it and it has been running smooth for a year.
I used a 32gb sd card with approx 10 gb used.
