I’ve got an interesting issue.
I’m trying to run Home Assistant on my server that runs about a billion services in my house, and if i run it from the command line, it works perfectly, and everything’s happy.
If I try to run it in the background as a service (either supervised or not) with the same parameters, it constantly restarts.
If I run it with -v to get an idea of what’s going on, the consistency I’m seeing before each restart is:
2024-07-15 11:05:01.666 INFO (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Pool recreating
And then a bunch of ‘Processing expected disconnect for ESPHome API’ or my ESPHome devices, and then it restarts.
Interestingly, it’s like it’s intentional on Home Assistant’s part, as it restarts itself and works fine (the supervisor/service isn’t what’s restarting it), but it just keeps restarting over and over.
But if I run it in a terminal window, it will run indefinitely without an issue.
The only differences I can see between the running processes is /proc//fd when I run it as a backgrounded service, FDs 1, and 2 are log files, and when I run it from the commandline, the FDs are /dev/pts/, as one might expect.
Anyone have any suggestions?
