Normally this wouldn’t be a problem, but it appears that Home Assistant does a ‘round robbin’ approach and makes use of the google DNS servers. (this is bad because I have devices that are only resolvable locally)
When I remove the google DNS servers from that config file, they are regenerated upon reboot.
how is this corefile created? and what is writing to it? and how can I stop 8.8.8.8 and 1.1.1.1 being amended to this file?
Hi Nato,
I had the same problem, after about 24h i found the solution!
Somehow there now is a file in /usr/share/hassio called dns.json. this file deterimes the dns servers, if you change it there and reboot it will work
Greetz, Jerry
Yeah I had the same, but since my personal dns was first it was working. let me know if you find a better solution. Also I dont know why it broke overnight, do you?
