Running homebridge and home assistant on the same pi
I have tried using the hassio addon for homebridge however i couldnt control the color of my lights properly, see this (https://github.com/home-assistant/homebridge-homeassistant/issues/265)
However when I installed HA manually onto raspbian and then installed homebridge normally with the homebridge-homeassistant plugin it works perfectly. When i went into home assistant though there was no hassio tab where i could install addons.
Is there a way i can install homebridge and home assistant (with the hassio tab) onto one rpi or can i install homebridge onto an rpi with hassio installed?
