Hello forum members,
I am taking my first steps on the home automation path an keep getting stuck, I could use your help. A little disclaimer up front: I am new computer operating system installation or installing booting and such. I have found that many of the guides assume this knowledge or take it for granted and skip steps that are not obvious to me, so please if you have advise brake it down to the lowest knowledge level.
I would like it very much to automate my home and switch on lights the bathroom fan based on my presence or the humidity and such. So I was thinking about using Home Assistant. After careful deliberations I choose the INTEL NUC, because I saw some youtube movies explaining that running it on a raspberry pie had some stability issues and running it on a mini computer would be more stable. So I bought a Intel NUC i3 with windows 10 pro. In the installation pages of Home assistant it looked pretty straight forward to install it on the NUC:
DOWNLOAD THE APPROPRIATE IMAGE
- Put the SD card in your card reader.
- Open balenaEtcher, select the Home Assistant image and flash it to the SD card.
- Unmount the SD card and remove it from your card reader.
- Once completed you will be able to reach Home Assistant on… (i have to break it off here I am apparently violating the number of links in this post…)
So, I also bought an SD card and started the installation: download balenaEtcher install it, flash the card, and nothing happend. (This is an example of what I mean that the guide assumes a lot of knowledge with the reader that I do not have and found after some some digging around.) I found out that the SD card only has the operating system on it and I have to boot the NUC up with it. That didn’t work apparently the NUC can not boot from the SD cardreader slot, I found that it can boot up from the sd cardreader and you have to have a card reader in the usb slot to make it boot from there. Since I didn’t have one I had to order it.
In the meanwhile I looked on the internet and found a youtube move explaining how to run Home Assistant under Windows 10 (I can’t link it in this post), it seemed pretty straight forward to me, so I did that and it worked! I could see my Sonos and could play it and I could turn on and off the HUE-lights, so I was a happy camper. I ordered a Sonoff humidity sensor to switch on or off the bathroom fan. For which I need a ConBee II Zigbee usb stick (…) After receiving them I tried to install the Zigbee stick in the NUC running Home Assistant under Windows 10. And It didn’t work, I could not find the serial device path, I assumed this was because it was running under windows 10 and because running Home Assistant under Windows 10 also does not support the hasio supervisor, I decided to try booting the NUC from the SD-cardreader that I also received in the mail.
After some fiddling around in the BIOS I could let the NUC boot from the SDcard in the reader. At least I think so, I saw some text flashing on the screen, and after a while this ended with a white prompt. So I thought: this must be it, so I tried to reach Home assistant from my other pc (from step 4 in the guide above), but none of the options work, both my windows pc and the NUC are connected to my local network via UTP cables to a router.
So I am out of options, if you can help me with what next steps to take or maybe use a different approach, I would really appreciate it.
Thank you,
Frans
