I’ve had hassio run for about 40 days and I just noticed that my storage is really low. I’m running it on a 32GB sd card and I now apparently there are only 2.6GB free. I remember when I first installed everything I had 20+GB free. How is this possible?
Anyone else had this problem or knows how to work out where all the space has gone?
I don’t have many addons either. So I really don’t understand what’s happened
Maybe you have an entity that generates a lot of data, that is being stored. You could try to find out which one it is and then exclude it or you could overall set the purge days to a lower value.
I use a 16Gb card in a Pi3 and I am running completely out of space. But my hassio doesn’t have any configuration at all, since it is not my main HA installation. I use ir only for running some addons at the moment, so I thought (and still believe) that a 16Gb card would be enough.
Thanks, but not worked. If I execute the “du -sh /” it show me 94mb used (after .db clean up) but if I use the “df -h” it show me 13.3Gb used (still with 100% used). Why this difference?
Your database is 94MB? You should set up the recorder component to purge your data every so often and exclude any entities you don’t want to be logged to keep the database as small as possible.
But if it isn’t the database that takes up all the space, then maybe some add-on?
