I’m trying to run the Lightwave Proxy service (Lightwave-TRV) but it seems almost impossible to run it through Home Assistant in the flashed Raspberry version.
Any ideas?
If I run AppDaemon, can I use pip3 install xxxx
I want to install the service so that I can read out the broadcast TRV responses, but without it, I’m stuffed.
I’m startnig to think that installing a developer version might be a much easier way to use than the docker version.
