Hi all,
I have set up reverse proxies using the built in RP manager in Synology DSM 7. Everything is working as expected on that machine, and I can access my Docker containers using the hostnames I’ve defined. I have a Pi running HASS on the same network, and after a lot of tinkering I’m close (I think) to getting it to work. I was getting a 400 error initially, but then I added a trusted proxies entry to my HASS config. Now it’s hitting the HASS instance on the Pi, but I get the HASS splash screen and an “unable to connect” error. Here’s the RP setup on my Synology:
YAML:
homeassistant:
external_url: https://hass.mydomain.synology.me
internal_url: http://192.168.1.80:8123
http:
use_x_forwarded_for: true
trusted_proxies:
- 192.168.1.50
(My Synology is at the 1.50 address, the Hass Pi is at 1.80)
Certificates are managed on the Synology, and they work fine with Docker containers. Can anyone spot what I’m doing wrong?
Any help would be greatly appreciated!
