I want to run an AppleScript on my Macbook from HA as part of an Automation.
I’ve set up ssh keys and running the command through the Terminal & SSH Add-on works without entering a password.
ssh -i /root/config/ssh/id_rsa -o 'StrictHostKeyChecking=no' [email protected] osascript /Users/maxerdmann/Documents/Wake.scpt
I’ve set up the same command as a shell service in the configuration.jaml:
shell_command:
wake: ssh -i /root/config/ssh/id_rsa -o 'StrictHostKeyChecking=no' [email protected] osascript /Users/maxerdmann/Documents/Wake.scpt
Trying to run in through developer tools returns the following error:
Error running command: `ssh -i /root/config/ssh/id_rsa -o 'StrictHostKeyChecking=no' [email protected] osascript /Users/maxerdmann/Documents/Wake.scpt`, return code: 255
NoneType: None
Any pointers as to what im doing wrong would be appreciated.
update:
got it to work using
ssh -F /etc/ssh/ssh_config -i /config/ssh/id_rsa [email protected] 'osascript /Users/maxerdmann/Documents/Wake.scpt' 2> /config/command.log
thanks to this post: Error when executing SSH command using command line switch
