I am having trouble calling a shell script to auto update HA config from a github repo once it passes a Travis-CI build. Below is the workflow:
Make local change on laptop -> commit -> push to github -> Travis-CI builds and runs hass -c . --script check_config -> if passes then automation on HA is triggered -> HA pulls the github change -> HA reloads config file
I have all the parts and scripts written to make this workflow but HA cannot seem to find the script.
/home//homeassistant/.homeassistant/configuration.yaml
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: !secret latitude
longitude: !secret longitude
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 83
# metric for Metric, imperial for Imperial
unit_system: imperial
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: America/New_York
customize: !include_dir_merge_named customize
mqtt:
broker: 127.0.0.1
port: 1883
username: !secret mqtt_username
password: !secret mqtt_password
# Show links to resources in log and frontend
#introduction:
# Enables the frontend
frontend:
http:
# Uncomment this to add a password (recommended!)
# api_password: PASSWORD
# Uncomment this if you are using SSL or running in Docker etc
# base_url: example.duckdns.org:8123
# Checks for available updates
updater:
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
#conversation:
# Enables support for tracking state changes over time.
history:
# View all events in a logbook
#logbook:
# Track the sun
sun:
#Customize binary sensors on home page
binary_sensor: !include ./configuration/binary_sensor.yaml
#Nest Climate config
climate: !include ./configuration/climate.yaml
#cover: !include ./configuration/cover.yaml
#UniFi Device Tracker
device_tracker: !include ./configuration/device_tracker.yaml
#Dashboard groups
group: !include ./configuration/group.yaml
#http: !include ./configuration/http.yaml
#IFTTT Config API key
ifttt: !include ./configuration/ifttt.yaml
#input_boolean: !include ./configuration/input_boolean.yaml
#input_select: !include ./configuration/input_select.yaml
#light: !include ./configuration/light.yaml
#Chromecast and other Media Players
media_player: !include ./configuration/media_player.yaml
#mqtt: !include ./configuration/mqtt.yaml
#Nest Config
nest: !include ./configuration/nest.yaml
#notify: !include ./configuration/notify.yaml
#remote: !include ./configuration/remote.yaml
script: !include_dir_merge_named script
#Sensors
sensor: !include ./configuration/sensor.yaml
switch: !include ./configuration/switch.yaml
# Text to speech
tts: !include ./configuration/tts.yaml
#Automations
automation: !include_dir_merge_list automation
config:
shell_command: !include_dir_merge_named shell_command
/home/homeassistant/.homeassistant/automation/update_config.yaml
- alias: 'Update config if travis build is successfull'
platform: state
entity_id: sensor.travis_build_label
condition:
- condition: state
entity_id: sensor.travis_status
state: 'Success'
- service: shell_command.update_config_from_github
/home/homeassistant/.homeassistant/configuration/sensor.yaml
#Travis-CI Integration
- platform: command_line
command: /usr/bin/curl -X GET https://api.travis-ci.org/repos/claughinghouse/homeassistant/cc.xml | grep lastBuildStatus | cut -d'"' -f2
scan_interval: 60
name: Travis Build Label
command: /usr/bin/curl -X GET https://api.travis-ci.org/repos/claughinghouse/homeassistant/cc.xml | grep lastBuildLabel | cut -d'"' -f2
scan_interval: 60
/home/homeassistant/.homeassistant/script/get_latest_config.sh
#!/bin/bash
cd "/home/homeassistant/.homeassistant"
git pull
sudo systemctl restart home-assistant@homeassistant
/home/homeassistant/.homeassistant/shell_command/update_config_from_github.yaml
'bash /home/homeassistant/.homeassistant/script/get_latest_config.sh'
I thought that I had this working but I keep receiving the error
2017-06-27 12:16:37 WARNING (MainThread) [homeassistant.core] Unable to find service shell_command/update_config_from_github
I tried to follow the HA configs from Tommatheussen, CCOSTAN, update-from-github-and-restart, and update-config-automatically-if-travis-ci-build-succeeds but I think that I am missing something simple or implemented something incorrectly. I can execute the script as the homeassistant user locally to pull the repo and restart HA.
The shell_command and script docs pages are confusing to me and I cannot figure out how to implement them properly.
You can view my current config here in case my config posts do not make sense.
Thank you!!!
