Running Supervised on Ubuntu 21.10
Hello Guys!
I’m new to HomeAssistant and just finished setting up a Supervised system on Ubuntu 21.10. In the supervisor I see a message about the unhealthy installation because of * [Supervisor is not privileged]. Can you please help me on how to sort this out ?
Many thanks in advance!
If you fix it, it may remove “unhealthy” status but will continue to report “unsupported”. That’s because only Debian is officially supported (all other Linux distros are only supported by the community, not the development team).
The “Supervisor is not privileged” message is probably because it doesn’t have exclusive root-level access to the docker containers. I don’t know which installation instructions you followed but it would appear it may have deviated from the official one:
Hey, thanks for your quick reply.
I was following this one:
https://peyanski.com/how-to-install-home-assistant-supervised-official-way/
Follow the one in the official documentation:
Install Home Assistant Supervised
