Is it somehow possible to run two scripts/services at the same time in one automation? See example below. I realize that service is looking for a single service to run but I am thinking it should be possible to accomplish this somehow, or am I wrong?
toggle_home_lights:
alias: "Toggle Home lights"
sequence:
service: >
{% if states ('sensor.template_total_lights_on') | int > 0 %}
script.turn_off_home_lights,
script.outside_night_mode
{% else %}
script.turn_on_home_lights
{% endif %}
I’m sorry for not following, please bare with me.
I want to press a button or element that calls “toggle_home_lights”.
If more than 0 lights (or any other number I specify) are lit, I want all home lights and some of the outside lights to go off.
If 0 lights are lit I want to turn on all home lights (but not any of the outside lights.
I want to be able to call this from several places in my UI, hence why I don’t want to configure a button as a trigger. This is a script that I want to be able to run from anywhere, and I want this script in turn to execute either two scripts (if lights are on) or one other script (if lights are off).
