Hi all !!
I currently run Home Assistant OS on a VM on proxmox, i currently have VLC-TELNET addon working fine through the audio 3.5 jack, as i did the hardware passthrough.
Now, i was able to passthrough an USB audio card, and its also working fine when i change the output device on VLC-Telnet, but my question is:
How to properly have two VLC instances, or how to output two different audio files to each soundcard.
I was able to clone the VLC repository and install a second addon, i was tinkering with the config files, but i was not able to make the integration work.
Any advices ?
Thank you a lot !
