#freshcoast
Thanks, I was afraid my mqtt might be the problem. I DO have OpenZWave integration installed. So this is what I did:
Stopped OpenZWave Add-on
Stopped my OS installed mqtt broker
Removed mqtt from my configuration.yaml
Restarted HA
Checked that mqtt ware all gone
Added Mosquitto Broker Add-on, left configs all default
Started Mosquitto broker
Started OpenZWave again.
Went to mqtt integration and used the tool to listen to #, I see a ton of zwave messages
Still no entities are showing up
Here are my log files
Mosquitto broker:
[06:42:15] INFO: Setup mosquitto configuration
[06:42:15] WARNING: SSL not enabled - No valid certs found!
[06:42:15] INFO: No local user available
[06:42:15] INFO: Initialize Hass.io Add-on services
[06:42:16] INFO: Initialize Home Assistant discovery
[06:42:16] INFO: Start Mosquitto daemon
1598881336: mosquitto version 1.6.3 starting
1598881336: Config loaded from /etc/mosquitto.conf.
1598881336: Loading plugin: /usr/share/mosquitto/auth-plug.so
1598881336: |-- *** auth-plug: startup
1598881336: ├── Username/password checking enabled.
1598881336: ├── TLS-PSK checking enabled.
1598881336: └── Extended authentication not enabled.
1598881336: Opening ipv4 listen socket on port 1883.
1598881336: Opening ipv6 listen socket on port 1883.
1598881336: Opening websockets listen socket on port 1884.
1598881336: Warning: Mosquitto should not be run as root/administrator.
1598881373: New connection from 192.168.1.60 on port 1883.
1598881373: Socket error on client <unknown>, disconnecting.
1598881394: New connection from 172.30.32.1 on port 1883.
[INFO] found homeassistant on local database
1598881395: New client connected from 172.30.32.1 as auto-79450449-3FC5-00B8-71F9-F830F4108A91 (p2, c1, k60, u'homeassistant').
1598881444: Socket error on client auto-79450449-3FC5-00B8-71F9-F830F4108A91, disconnecting.
1598881444: New connection from 172.30.32.1 on port 1883.
1598881444: New client connected from 172.30.32.1 as auto-579F0709-57A2-F21E-7D1A-0ABB1FE33FDD (p2, c1, k60, u'homeassistant')
1598881493: New connection from 192.168.1.60 on port 1883.
1598881493: Socket error on client <unknown>, disconnecting.
1598881523: New connection from 172.30.33.1 on port 1883.
[INFO] found addons on local database
1598881524: New client connected from 172.30.33.1 as mosq-BW3t1FGQpTXpFRjLj1 (p2, c1, k60, u'addons').
1598881524: Client mosq-BW3t1FGQpTXpFRjLj1 disconnected.
1598881525: New connection from 172.30.33.1 on port 1883.
1598881525: New client connected from 172.30.33.1 as mosq-HXiu8CuAHqLqgq58Ty (p2, c1, k60, u'addons').
1598881525: Client mosq-HXiu8CuAHqLqgq58Ty disconnected.
1598881527: New connection from 172.30.33.1 on port 1883.
1598881527: New bridge connected from 172.30.33.1 as zwave (p2, c1, k60, u'addons').
1598881613: New connection from 192.168.1.60 on port 1883.
1598881613: Socket error on client <unknown>, disconnecting.
1598881733: New connection from 192.168.1.60 on port 1883.
1598881733: Socket error on client <unknown>, disconnecting.
OpenZWave:
(there are some breaks where I could not capture the log fast enought)
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] auth.sh: executing...
[06:45:21] INFO: Auth database exists
[cont-init.d] auth.sh: exited 0.
[cont-init.d] mqtt.sh: executing...
[06:45:25] INFO: Connected to internal MQTT service
[cont-init.d] mqtt.sh: exited 0.
[cont-init.d] network_key.sh: executing...
[cont-init.d] network_key.sh: exited 0.
[cont-init.d] novnc.sh: executing...
[cont-init.d] novnc.sh: exited 0.
[cont-init.d] structure.sh: executing...
[cont-init.d] structure.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[06:45:27] INFO: Starting internal MQTT broker...
1598881527: mosquitto version 1.6.8 starting
1598881527: Config loaded from /etc/mosquitto.conf.
1598881527: Opening ipv4 listen socket on port 1883.
1598881527: Opening ipv6 listen socket on port 1883.
1598881527: Warning: Mosquitto should not be run as root/administrator.
1598881527: Connecting bridge main-mqtt (core-mosquitto:1883)
[20200831 6:45:45.099 PDT] [ozw.nodes] [debug]: setNodeData 6 : QTOZW_Nodes::NodeDeviceType : QVariant(int, 6656) Transaction: true
[20200831 6:45:45.099 PDT] [ozw.nodes] [debug]: setNodeData 6 : QTOZW_Nodes::NodeDeviceTypeString : QVariant(QString, "Window Covering Position/Endpoint Aware") Transaction: true
[20200831 6:45:45.099 PDT] [ozw.nodes] [debug]: setNodeData 6 : QTOZW_Nodes::NodeRole : QVariant(int, 7) Transaction: true
[20200831 6:45:45.099 PDT] [ozw.nodes] [debug]: setNodeData 6 : QTOZW_Nodes::NodeRoleString : QVariant(QString, "Listening Sleeping Slave") Transaction: true
[20200831 6:45:45.099 PDT] [ozw.nodes] [debug]: setNodeData 6 : QTOZW_Nodes::NodePlusType : QVariant(int, 0) Transaction: true
[20200831 6:45:45.100 PDT] [ozw.nodes] [debug]: setNodeData 6 : QTOZW_Nodes::NodePlusTypeString : QVariant(QString, "Z-Wave+ node") Transaction: true
[20200831 6:45:45.100 PDT] [ozw.nodes] [debug]: setNodeData 6 : QTOZW_Nodes::NodeQueryStage : QVariant(QString, "Complete") Transaction: true
[20200831 6:45:45.101 PDT] [ozw.library] [debug]: Detail - Node: 6 AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
[20200831 6:45:45.101 PDT] [ozw.library] [debug]: Detail - Node: 6 QueryStage_Configuration
[20200831 6:45:45.101 PDT] [ozw.library] [debug]: Detail - Node: 6 QueryStage_Complete
[20200831 6:45:45.102 PDT] [ozw.library] [warning]: Warning - Node: 0 CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=1
[20200831 6:45:45.102 PDT] [ozw.library] [warning]: Warning - Node: 0 CheckCompletedNodeQueries all=0, deadFound=0 sleepingOnly=1
[20200831 6:45:45.102 PDT] [ozw.library] [info]: Info - Node: 0 Saving Cache
[20200831 6:45:45.103 PDT] [ozw.library] [debug]: Detail - Node: 6 Notification: NodeQueriesComplete
[20200831 6:45:45.104 PDT] [ozw.library] [info]: Info - Node: 1 Cache Save for Node 1 as its QueryStage_CacheLoad
[20200831 6:45:45.106 PDT] [ozw.library] [info]: Info - Node: 4 Cache Save for Node 4 as its QueryStage_CacheLoad
[20200831 6:45:45.109 PDT] [ozw.library] [info]: Info - Node: 5 Cache Save for Node 5 as its QueryStage_CacheLoad
[20200831 6:45:45.111 PDT] [ozw.library] [info]: Info - Node: 6 Cache Save for Node 6 as its QueryStage_CacheLoad
[20200831 6:45:45.113 PDT] [ozw.library] [info]: Info - Node: 7 Cache Save for Node 7 as its QueryStage_CacheLoad
[20200831 6:45:45.149 PDT] [default] [debug]: QVariant(int, 6)
[20200831 6:45:45.149 PDT] [default] [debug]: QVariant(QString, "")
[20200831 6:45:45.150 PDT] [default] [debug]: QVariant(QString, "Springs Window Fashions (Graber)")
[20200831 6:45:45.150 PDT] [default] [debug]: QVariant(QString, "CSZ1 Cellular Shade")
[20200831 6:45:45.150 PDT] [default] [debug]: QVariant(QString, "Routing Slave")
[20200831 6:45:45.150 PDT] [default] [debug]: QVariant(int, 4)
[20200831 6:45:45.151 PDT] [default] [debug]: QVariant(QString, "Multilevel Switch")
[20200831 6:45:45.151 PDT] [default] [debug]: QVariant(int, 17)
[20200831 6:45:45.151 PDT] [default] [debug]: QVariant(QString, "Motor Control Class C")
[20200831 6:45:45.152 PDT] [default] [debug]: QVariant(int, 7)
[20200831 6:45:45.152 PDT] [default] [debug]: QVariant(QString, "Window Covering Position/Endpoint Aware")
[20200831 6:45:45.152 PDT] [default] [debug]: QVariant(int, 6656)
[20200831 6:45:45.153 PDT] [default] [debug]: QVariant(QString, "Listening Sleeping Slave")
[20200831 6:45:45.153 PDT] [default] [debug]: QVariant(int, 0)
[20200831 6:45:45.153 PDT] [default] [debug]: QVariant(QString, "Z-Wave+ node")
[20200831 6:45:45.154 PDT] [default] [debug]: QVariant(QString, "Complete")
[20200831 6:45:45.154 PDT] [default] [debug]: QVariant(QString, "0x026e")
[20200831 6:45:45.154 PDT] [default] [debug]: QVariant(QString, "0x4353")
[20200831 6:45:45.154 PDT] [default] [debug]: QVariant(QString, "0x5a31")
[20200831 6:45:45.155 PDT] [default] [debug]: QVariant(uint, 100000)
[20200831 6:45:45.155 PDT] [default] [debug]: QVariant(int, 4)
[20200831 6:45:45.155 PDT] [default] [debug]: QVariant(int, 1)
[20200831 6:45:45.156 PDT] [default] [debug]: QVariant(QBitArray, QBitArray(0111 0111 0))
[20200831 6:45:45.159 PDT] [ozw.mqtt.publisher] [debug]: Publishing Event nodeQueriesComplete: 6
[20200831 6:45:45.159 PDT] [ozw.notifications] [debug]: Notification pvt_nodeQueriesComplete 5 Thread: 0x76fe9558
[20200831 6:45:45.160 PDT] [default] [debug]: QVariant(int, 5)
[20200831 6:45:45.160 PDT] [default] [debug]: QVariant(QString, "")
[20200831 6:45:45.161 PDT] [default] [debug]: QVariant(QString, "")
[20200831 6:45:45.161 PDT] [default] [debug]: QVariant(QString, "Springs Window Fashions (Graber)")
[20200831 6:45:45.161 PDT] [default] [debug]: QVariant(QString, "CSZ1 Cellular Shade")
[20200831 6:45:45.161 PDT] [default] [debug]: QVariant(QString, "Routing Slave")
[20200831 6:45:45.162 PDT] [default] [debug]: QVariant(int, 4)
[20200831 6:45:45.162 PDT] [default] [debug]: QVariant(QString, "Multilevel Switch")
[20200831 6:45:45.162 PDT] [default] [debug]: QVariant(int, 17)
[20200831 6:45:45.162 PDT] [default] [debug]: QVariant(QString, "Motor Control Class C")
[20200831 6:45:45.163 PDT] [default] [debug]: QVariant(int, 7)
[20200831 6:45:45.163 PDT] [default] [debug]: QVariant(QString, "Window Covering Position/Endpoint Aware")
[20200831 6:45:45.163 PDT] [default] [debug]: QVariant(int, 6656)
[20200831 6:45:45.164 PDT] [default] [debug]: QVariant(QString, "Listening Sleeping Slave")
[20200831 6:45:45.164 PDT] [default] [debug]: QVariant(int, 0)
[20200831 6:45:45.164 PDT] [default] [debug]: QVariant(QString, "Z-Wave+ node")
[20200831 6:45:45.164 PDT] [default] [debug]: QVariant(QString, "Complete")
[20200831 6:45:45.164 PDT] [default] [debug]: QVariant(QString, "0x026e")
[20200831 6:45:45.165 PDT] [default] [debug]: QVariant(QString, "0x4353")
[20200831 6:45:45.165 PDT] [default] [debug]: QVariant(QString, "0x5a31")
[20200831 6:45:45.165 PDT] [default] [debug]: QVariant(uint, 100000)
[20200831 6:45:45.165 PDT] [default] [debug]: QVariant(int, 4)
[20200831 6:45:45.165 PDT] [default] [debug]: QVariant(int, 1)
[20200831 6:45:45.166 PDT] [default] [debug]: QVariant(QBitArray, QBitArray(0111 0111 0))
[20200831 6:45:45.168 PDT] [ozw.mqtt.publisher] [debug]: Publishing Event nodeQueriesComplete: 5
[20200831 6:45:45.168 PDT] [ozw.notifications] [debug]: Notification pvt_nodeQueriesComplete 6 Thread: 0x76fe9558
[20200831 6:45:45.169 PDT] [default] [debug]: QVariant(int, 6)
[20200831 6:45:45.169 PDT] [default] [debug]: QVariant(QString, "")
[20200831 6:45:45.169 PDT] [default] [debug]: QVariant(QString, "Springs Window Fashions (Graber)")
[20200831 6:45:45.169 PDT] [default] [debug]: QVariant(QString, "CSZ1 Cellular Shade")
[20200831 6:45:45.169 PDT] [default] [debug]: QVariant(QString, "Routing Slave")
[20200831 6:45:45.170 PDT] [default] [debug]: QVariant(int, 4)
[20200831 6:45:45.170 PDT] [default] [debug]: QVariant(QString, "Multilevel Switch")
[20200831 6:45:45.170 PDT] [default] [debug]: QVariant(int, 17)
[20200831 6:45:45.170 PDT] [default] [debug]: QVariant(QString, "Motor Control Class C")
[20200831 6:45:45.170 PDT] [default] [debug]: QVariant(int, 7)
[20200831 6:45:45.170 PDT] [default] [debug]: QVariant(QString, "Window Covering Position/Endpoint Aware")
[20200831 6:45:45.170 PDT] [default] [debug]: QVariant(int, 6656)
[20200831 6:45:45.170 PDT] [default] [debug]: QVariant(QString, "Listening Sleeping Slave")
[20200831 6:45:45.171 PDT] [default] [debug]: QVariant(int, 0)
[20200831 6:45:45.171 PDT] [default] [debug]: QVariant(QString, "Z-Wave+ node")
[20200831 6:45:45.171 PDT] [default] [debug]: QVariant(QString, "Complete")
[20200831 6:45:45.171 PDT] [default] [debug]: QVariant(QString, "0x026e")
[20200831 6:45:45.171 PDT] [default] [debug]: QVariant(QString, "0x4353")
[20200831 6:45:45.171 PDT] [default] [debug]: QVariant(QString, "0x5a31")
[20200831 6:45:45.171 PDT] [default] [debug]: QVariant(uint, 100000)
[20200831 6:45:45.171 PDT] [default] [debug]: QVariant(int, 4)
[20200831 6:45:45.171 PDT] [default] [debug]: QVariant(int, 1)
[20200831 6:45:45.172 PDT] [default] [debug]: QVariant(QBitArray, QBitArray(0111 0111 0))
[20200831 6:45:45.173 PDT] [ozw.mqtt.publisher] [debug]: Publishing Event nodeQueriesComplete: 6
[20200831 6:45:46.678 PDT] [ozw.library] [info]: Info - Node: 0 HttpThread Exiting. No Transfers in timeout period
[20200831 6:46:06.688 PDT] [default] [debug]: QVariant(int, 1)
[20200831 6:46:06.689 PDT] [default] [debug]: QVariant(int, 4)
[20200831 6:46:06.690 PDT] [default] [debug]: QVariant(int, 5)
[20200831 6:46:06.692 PDT] [default] [debug]: QVariant(int, 6)
[20200831 6:46:06.693 PDT] [default] [debug]: QVariant(int, 7)
[20200831 6:46:32.695 PDT] [ozw.mqtt.publisher] [debug]: "Mon Aug 31 06:46:32 2020 PingResponse\n"
[20200831 6:46:36.673 PDT] [default] [debug]: QVariant(int, 1)
[20200831 6:46:36.675 PDT] [default] [debug]: QVariant(int, 4)
[20200831 6:46:36.676 PDT] [default] [debug]: QVariant(int, 5)
[20200831 6:46:36.678 PDT] [default] [debug]: QVariant(int, 6)
[20200831 6:46:36.679 PDT] [default] [debug]: QVariant(int, 7)
[20200831 6:47:06.698 PDT] [default] [debug]: QVariant(int, 1)
[20200831 6:47:06.700 PDT] [default] [debug]: QVariant(int, 4)
[20200831 6:47:06.701 PDT] [default] [debug]: QVariant(int, 5)
[20200831 6:47:06.702 PDT] [default] [debug]: QVariant(int, 6)
[20200831 6:47:06.703 PDT] [default] [debug]: QVariant(int, 7)
