Hi guys,
I was wondering if the community had any tips or suggestions on my current (non working) irrigation set up.
Currently I have 2 1000L IBC tanks at the top of our property, and then a 3/4 inch pipe that runs down to one of our garden patches. The distance is approx 100 meters with a drop of 6 meters between the two distances.
Currently we have it connect to a tap but we did want to have a manifold with some solanoid valves to direct water to different garden beds (on of them back up the hill about 10 meters)
Not researching enough, I bought 2 solenoid valves that had a minimum pressure of 70kpa and tried to install them about 5 meters back up the hill. Water just continuted to flow out of them slowly and after research i learnt that it needs pressure to keep them closed as well as open.
I did a “bucket test” on the tap at the bottom of the hill and it only runs at about 13.5LPM which I guess is also still quite low?
I have not done a pressure test yet to test the Kpa, I will buy one of these on the weekend.
My question is, what would be the solution to getting better water pressure / flow that i can distribute out to the different garden beds via automation such as the solenoids and home assistant?
Would a pressure pump help with this? I notice when the tap is turned on full, it starts off fast, then slows down as well as splatters just a little bit, so it is not just pure flow, it is struggling to get to the tap fast enough? (When i turn the tap off for 5-10 seconds and turn it back on, it flows fast again for a little while and then slows again.
If that is the case, would a pump still help or is my issue elsewhere?
Also just to note, between the tank and the tap, there is about 5 elbow connectors… I read that they do reduce flow, but not by a lot. We dont really have any options to remove them as the pipe is all underground.
Would love to hear any suggestions you have… let me know if you guys want any pictures of my setup if it will help.
Thanks in advance
Ryan
