Russound Config with x86/64 system
Hey so I’m running Home Assistant on a Lenovo PC running the x86/64 firmware, and i’m attempting to use the Russound RNET integration with USB to RS232 cables. I’m having trouble getting the data to translate TCP to serial. Is there way to setup the serial to be able to send the messages properly, or something that i can use to do the TCP to serial conversion.
Settings? Logs? Which russound device? Are you using a null modem cable?
I have 2 Cav 6.6, i have a USB->RS232 cable hooked up to the Lenovo PC.
Right now my config is very simple
Let me know what other information you need from me.
logs, like i said
