Russound RIO mute errors
I’m trying to get the Russound RIO integration working. Volume up/down and source is working but mute does not. Anyone have this issue or know a fix?
Here is the error I found in HA logs
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:245
integration: Home Assistant WebSocket API (documentation, issues)
First occurred: December 14, 2024 at 10:51:45 AM (38 occurrences)
Last logged: December 14, 2024 at 11:31:08 AM
[139711619796272] Unexpected exception
[139711636035408] Unexpected exception
[139711623586016] Unexpected exception
[139711642687744] Unexpected exception
File “/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py”, line 245, in handle_call_service
response = await hass.services.async_call(
…<7 lines>…
File “/usr/src/homeassistant/homeassistant/core.py”, line 2802, in async_call
response_data = await coro
File “/usr/src/homeassistant/homeassistant/core.py”, line 2845, in _execute_service
return await target(service_call)
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 1007, in entity_service_call
single_response = await _handle_entity_call(
hass, entity, func, data, call.context
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 1079, in _handle_entity_call
result = await task
File “/usr/src/homeassistant/homeassistant/components/media_player/init.py”, line 811, in async_mute_volume
await self.hass.async_add_executor_job(self.mute_volume, mute)
File “/usr/local/lib/python3.13/concurrent/futures/thread.py”, line 58, in run
File “/usr/src/homeassistant/homeassistant/components/media_player/init.py”, line 807, in mute_volume
raise NotImplementedError
NotImplementedError
Hi @ferdaze,
Mute is not currently implemented. Support for mute on some devices will be available in the January release of HA.
Which Russound device are you using?
Ah … Thanks for the update. I want to use my Unfolded remote but that will have to wait a little longer.
I have the MCA-88.
