Will there be optional update as well for Ruuvi integration to Homeassitant with gyro & vibration related values as well?
Would like to get to Homeassistant from Ruuvitag BLE & Gateway:
- Acceleration for X, Y and Z axes (g)
- Movement counter
You’d want to open a feature request for those, which can be done here in the Feature Requests section (don’t forget to vote for your own request).
Hi @ismo67
You could try our Theengs Gateway HA Add-on, which includes the decoded values you are looking for, as described on the compatible devices list.
Thank you, this would be the option then if I need to go to MQTT setup.I still hope Ruuvi BLE & Ruuvi Gateway could start to support these values without MQTT setup.
