RX and TX on same 433mhz antenna?
I have a FS1000A TX and XY-MK-5V module that I use for controlling kaku modules:
It works quite well, but sometimes I see that some devices are not turned on or of as required, especially the ones that are the most far away from the sender.
Right now I have a short 17,5 wire antenna on both modules. I still have some big 35cm antenna’s (especially for 433 mhz), that I want to use instead of the wire antenna.
So I want to solder the core of the antenna coax to the antenna output of the module, and the foil to the ground.
I was wondering, could I connect both TX and RX to the same antenna (so bridging both antenna outputs, maybe with a filter), or would I blow my receiver then?
thanks
