Ryanair API for Home Assistant
This component will allow you to bring your upcoming Ryanair flight information into Home Assistant. The following information will be provided:
- Flight Number.
- Origin / Destination Airport code.
- Check in open / close time.
- Arrival / departure time.
- Passengers name and seat number.
- Mobile frienldy boarding passes.
- Number of upcoming flights.
- Flight cancellation status.
- Ryanair user account information.
- Upcoming flights count.
This project is very much a work in progress and there are still many issue that need addressing. If you have the skills, time and implication then please feel free to contribute.
Enjoying this? Help me out with a
or
Installation through HACS
Installation via HACS is not yet possible but there is a pending PR for that.
Once it's approved then you can use HACS to install the Ryanair integration.
Manual Installation
Use this route only if you do not want to use HACS and love the pain of manually installing regular updates.
- Add the
ryanairfolder in yourcustom_componentsfolder
Usage
Once installed, login with your Ryanair credentials (Social sign in is not supported!). If this is the first time logging in via this integration then you will have 10 minutes to enter the MFA code that is sent to your Ryanair email address.
