S0 pulse output home assistant
Hi. I wonder if anyone knows how to generate S0 pulses based on energy readings from a P1 port and output them from HA. I have a heating system from Daikin that need S0 pulses. Now I have all the data in HA through p1 port but is it possible som generate the pulses instead of adding even more meter to my electrical central. I need a s0 for the total and also for each phase.
The Same for me too. I Have all values in Homeassistant, with two Shelly 3EM, but i need Surplus Output in S0 for my Heatpump. The thing is, it is not possible to get a connection by wire to my Energy Meter, So im not able to install a S0 energy Meter. Is that possible to create a S0 Output in my Homeassistant Raspberry Pi?
Hi
I have exactly the same question.
I also have all the values in HomeAssistant, but my energy meter also does not have a S0 output which the heatpump requires.
The best information I’ve found so far by searching was with an internet search where I’ve this description “S0 - Signal mit Wemos D1 Mini erzeugen”. It’s for ioBroker however and is not a too detailed description.
Does anyone have any further information?
Thank you!
Hi @Eistee and @pretori
Is this still relevant for you?
I’m getting closer to a solution. I’m using an ESP32 with I’ve connected through MQTT to transfer the kW information to generate the corresponding pulses. I’m currently working on the hardware. Do you have some information about which diodes etc. should be used to generate an S0 signal? Thank you!
At this moment not for me, but all the guys with heat pumps need this to module Power…
Has anyone found a solution?
I’ve been trying to generate S0 pulses for controlling the power limitation of my heat pump (daikin altherma) based on my solar panel output. At the moment it’s not working (my heat pump does not detect the signal).
I use an ESP module with ESPhome to control a relay (or an optocouple, I tried both) on/off at the frequency of the pulse I want to generate. If I manage to make it work I’ll post it here, but so far my S0 signal looks good to me but my heat pump does not seem to detect it so not sure what I’m doing wrong…
I think I’ve managed to make it work. I try to detail below what I’ve done, but don’t hesitate to ask me if anything is unclear.
I use a NodeMCU (8266) with ESPHome linked to a relay board with (at least) 3 relays. The first two relays are used to control the smart grid contact on the daikin altherma 3 heat pump (contacts 5-6 and 9-10 on the X5M connector on my model). This is the standard smart grid control detailed in different projects (see for instance ESPAltherma).
I then use the third relay (an optocoupler would be better but I didn’t have one available at the moment) and connect it to the Smart grid pulse meter input of the daikin heat pump (connectors 3-4 of the X5M connector on my model).
I use the following configuration for ESPhome:
esphome:
  on_loop:
    then:
      - lambda: |-
          static uint32_t last_time = 0;
          static uint32_t start_pulse = 0;
          // 1000 imp/kWh =
          uint32_t pulse_width_ms = 1000*(3600*1000/1000)/(id(simu_power).state);
          uint32_t now = millis();
          if ((pulse_width_ms) > 0) {
            if (now - last_time > (pulse_width_ms)) {
                last_time = now;
                start_pulse = now;
                id(out_power_pulse).turn_on();
                ESP_LOGD("loop", "pulse_width_ms: %d", (pulse_width_ms));
          if (now - start_pulse > id(pulse_duration).state) {
                id(out_power_pulse).turn_off();
  platform: ESP8266
  board: nodemcuv2
wifi:
  ssid: YourSSID
  password: YourPassword
api:
ota:
number:
    name: "S0 Pulse Simulated Power"
    optimistic: true
    min_value: 0
    max_value: 4000
    step: 1
    initial_value: 0
    name: "So Pulse Duration"
    optimistic: true
    min_value: 0
    max_value: 800
    step: 1
    initial_value: 200
output:
  - platform: gpio
    pin: GPIO5
    inverted: true
  - platform: gpio
    pin: GPIO15
    inverted: true
  - platform: gpio
    pin: GPIO13
    inverted: true
select:
    options:
     - "Normal"
     - "Recommended On"
     - "Forced Off"
     - "Forced On"
    initial_option: "Normal"
    optimistic: true
    set_action:
      - logger.log:
          format: "Chosen option: %s"
          args: ["x.c_str()"]
    on_value:
      then:
      - lambda: |-
          if ( x == "Normal") {
            id(relay_1).turn_off();
            id(relay_2).turn_off();
          else if ( x == "Recommended On") {
            id(relay_1).turn_on();
          else if ( x == "Forced Off") {
            id(relay_2).turn_on();
          else if ( x == "Forced On") {
This configuration should generate a device with 3 entities:
  • one drop down which enable to select the smart grid setting (normal, recommended on, forced off, forced on)
  • a number input to enter the power value you want to simulate with the pulse (in watts)
  • a number input (default at 200 ms) to enter the length of the pulse you want to simulate (in ms)
when a power value other than 0 watts is entered, the ESP board starts to pulse the relay at the required frequency to generate 1000 pulses/ kWh.
On my ESP I use the GPIO 5, 13 and 15 to control the 3 relays, but you need to adapt this to the pins you use on your own board.
On the daikin the Smart Grid needs to be activated in the configuration:
  • “benefit kWh power supply” (menu item 9.8.4 for me) needs to be set to smart grid
  • “Limit setting kW” (menu item 9.8.8 for me) is on 0 (not sure this is really needed)
  • “Electricity meter 2” (menu item 9.A.2 for me) is set to “1000 pulses / kWh for PV panel”
Once you’ve plugged everything and configured a simulated power value, you need to let the pulse meter run for a good while (I think it took around 1h) for the heat pump to detect it. To check if it’s detected, you need to activate the smart grid to “recommended on” and then go to the information / operation modes menu to see what is the power limitation. Once it is detected, the heat pump seems to react well to changing the simulated power value (within 30 seconds here).
I’ve only managed to make it work today so maybe what is above will need to be adapted when I understand a bit better how it really works. Also at the moment I have not been able to test much since the heating / cooling is not needed here.
This is a very early test so what is above may not work well (or even at all) … and for the usual warning: if you tinker with your heat pump, there is risk of damage to it and I take no responsibility at all :sweat_smile:
The information above is mainly a compilation of the various posts I’ve read online from the ESPAltherma project , the P1P2MQTT project and from this post on ESPhome. Thanks to all of these super projects for enabling this fine control of my heat pump.
Hi there Bishop!
thanks a lot for commenting about your own update!
I have a Daiking Altherma 3 heating pump and I suspect you have the same product (but maybe a different model). I’m looking to achieve exactly the same as you so I’m very happy you have posted a solution!
In fact, I created an account just to ask: Could you please post an update here when you have one that might help others? You say you just got it to work today, I’m very interested to see what your findings are!
I haven’t gone much further than my previous post because for producing hot water the power limitation does not bring much. If you use power limitation, the heat pump does not have enough power to actually produce hot water so in practice you have to put the power limitation nearly at the maximum power capacity of the heat pump to be able to use the compressor to produce hot enough water (my booster resistor is set to activate only during legionella runs).
If I have time I will try some more during the cold season to see if it can be beneficial for buffering heat at low power. However, even this case may prove of limited use because the idea is to use the spare solar panels power (which will be small in winter). Also the room buffering works only if a thermostat is set up if I understood correctly whereas in my case I am controlling the temperature of the leaving water temperature (i.e. no thermostat installed).
I might try to connect a thermostat this winter to see if the buffering works but for the moment I couldn’t find a use case which makes controlling the power really useful unfortunately. I therefore usually use only the smart grid contacts to start the heat pump when there is PV production without restricting the power.
Let us know, if you test on your side, if it works and if you find some interesting ways to use it :slight_smile:
how is going ? did you manage it without thermostat? I wanna understand if effort to generate S0 is userfull or not.
Hi. In the end I’m not using the S0 pulses because I don’t have enough spare PV capacity in the winter to justify it (I’m basically consuming all of it anyway all the time). My HP is using weather dependent setting with no thermostat and I only play with the leaving water temperature to increase or reduce the power consumed by the HP. So as far as I’m concerned using the S0 pulse was a fun project but is not worth it (too complex and not applicable most of the time).
Hi Bishop,
I wanted to reach out one last time and say thank you for your post, which was the basis for my own journey to get this to work. I wrote a write-up about it here: https://gathering.tweakers.net/forum/list_message/82684186#82684186
it’s in Dutch, but for anyone wanting to achieve the same thing, just copy the page into a translation service (or better yet: AI chatbot) to whichever language you need and you should be good to go!
Thanks for the link to your post. It’s well written and very detailed and I’m happy to see that it works fine. I would be interested to know if you really use it in the end and if it helps with your consumption. In my case my spare PV power is not really enough to make the S0 pulse worth it (I’m just using the forced on mode when spare PV output is above 1.5kWh) , but maybe I should try again.
Have a good day :slight_smile:
In the Netherlands we have something called the “salderingsregeling”, which means I can basically use the powergrid as my battery (as far as my wallet is concerned. I get the same price for exporting as i pay for importing power), so right now it’s best to only use my own solar if the price is worth it which means i basically want to move all my power usage to the cheapest hours of the day, regardless of excess solar production.
This will no longer be the case from 1 jan 2027, and from then on any excess solar I sell will basically give me almost no money. So from that moment on I will use it. My solar production varies from 0-6kW, so there’s definitely times when this will be the better option.
I think your solution works fine as long as you don’t allow electric heaters in smart grid “recommended ON” mode (or use a flat value of 2,5kW or lower), and as long as you don’t exceed solar production to want to use that electric water heater element (Booster) at all.
In my case, I want to use the Booster element from 2027 onwards whenever solar energy exceeds 3kW, but probably sooner. I’ll have to make the calculations at a later point what the sweet spot is where, for example, the benefit of heating the water tank with 75% solar energy and 25% grid energy is worth the cost.
I might start using the S0 mode earlier to give some time to test out multiple devices using solar power (my electric car) and seeing how the heatpump and car charger behave when both want to run on solar power. I’m gonna guess that’s going to be a race condition, but I’ll know it when I use it like that.
