Here is the new config, still not working. I can hear it trying and then it appears to crash. I assume I have to hook it up to computer so I can read logs instead of wireless?
esphome:
friendly_name: creative-d80
platformio_options:
board_build.flash_mode: dio
esp32:
board: esp32-s3-devkitc-1
variant: ESP32S3
flash_size: 16MB
framework:
type: esp-idf
version: recommended
sdkconfig_options:
# need to set a s3 compatible board for the adf-sdk to compile
# board specific code is not used though
CONFIG_ESP32_S3_BOX_BOARD: "y"
CONFIG_ESP32_WIFI_STATIC_RX_BUFFER_NUM: "16"
CONFIG_ESP32_WIFI_DYNAMIC_RX_BUFFER_NUM: "512"
CONFIG_TCPIP_RECVMBOX_SIZE: "512"
CONFIG_TCP_SND_BUF_DEFAULT: "65535"
CONFIG_TCP_WND_DEFAULT: "512000"
CONFIG_TCP_RECVMBOX_SIZE: "512"
psram:
mode: octal
speed: 80MHz
external_components:
- source:
type: git
url: https://github.com/gnumpi/esphome_audio
ref: dev-next
components: [ adf_pipeline, i2s_audio ]
refresh: 0s
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: ""
ota:
- platform: esphome
password: ""
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Creative-D80 Fallback Hotspot"
password: ""
captive_portal:
i2s_audio:
- id: i2s_out
i2s_lrclk_pin: GPIO05
i2s_bclk_pin: GPIO04
adf_pipeline:
- platform: i2s_audio
type: audio_out
i2s_audio_id: i2s_out
i2s_dout_pin: GPIO18
media_player:
- platform: adf_pipeline
internal: false
keep_pipeline_alive: false
pipeline:
- self
- adf_i2s_out
And I am getting logs now after I plug it back in.
10:46:16][D][api.connection:1375]: Home Assistant 2024.7.3 (192.168.0.50): Connected successfully
[10:47:01][I][safe_mode:041]: Boot seems successful; resetting boot loop counter
[10:47:01][D][esp32.preferences:114]: Saving 1 preferences to flash...
[10:47:01][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[10:47:26][D][media_player:061]: 'media player' - Setting
[10:47:26][D][media_player:068]: Media URL: http://192.168.0.50:8097/flow/media_player.creative_d80_media_player/c655dd5790dd4af5bfe221351e45d0fd.mp3?ts=1723474046
WARNING creative-d80 @ 192.168.107.145: Connection error occurred: [Errno 104] Connection reset by peer
INFO Processing unexpected disconnect from ESPHome API for creative-d80 @ 192.168.107.145
WARNING Disconnected from API
INFO Successfully connected to creative-d80 @ 192.168.107.145 in 0.005s
INFO Successful handshake with creative-d80 @ 192.168.107.145 in 0.069s
[10:47:56][D][api:102]: Accepted 192.168.0.50
[10:47:56][D][api.connection:1375]: Home Assistant 2024.7.3 (192.168.0.50): Connected successfully
[10:59:07][D][media_player:061]: 'media_player' - Setting
[10:59:07][D][media_player:068]: Media URL: http://192.168.0.50:8097/single/media_player.creative_d80_media_player/5a9440b89d4a48a78cda309c7a154632.mp3?ts=1723474747
[10:59:07][D][esp_audio_sources:098]: Set new uri: http://192.168.0.50:8097/single/media_player.creative_d80_media_player/5a9440b89d4a48a78cda309c7a154632.mp3?ts=1723474747
[10:59:07][D][adf_media_player:057]: Got control call in state IDLE
[10:59:07][D][adf_media_player:058]: req_track stream uri: http://192.168.0.50:8097/single/media_player.creative_d80_media_player/5a9440b89d4a48a78cda309c7a154632.mp3?ts=1723474747
[10:59:07][D][esp_adf_pipeline:060]: Starting request, current state UNINITIALIZED
[10:59:07][D][esp_adf_pipeline:448]: [MediaPlayer] Pipeline changed from UNINITIALIZED to INITIALIZING. (REQ: 0)
[10:59:07][I][adf_media_player:192]: got new pipeline state: 1, while in MP state IDLE
[10:59:07][I][adf_media_player:256]: current mp state: IDLE
[10:59:07][I][adf_media_player:257]: anouncement: false
[10:59:07][I][adf_media_player:258]: play_intent: false
[10:59:07][I][adf_media_player:259]: current_uri_: yes
[10:59:07][D][esp-idf:000]: I (229754) MP3_DECODER: MP3 init
[10:59:07][D][i2s_audio:067]: Install driver requested by Writer
[10:59:07][D][esp-idf:000]: I (229758) I2S: DMA Malloc info, datalen=blocksize=2048, dma_buf_count=4
[10:59:07][D][i2s_audio:073]: Installing driver : yes
[10:59:07][D][esp_adf_pipeline:497]: pipeline tag 0, http
[10:59:07][D][esp_adf_pipeline:497]: pipeline tag 1, decoder
[10:59:07][D][esp_adf_pipeline:497]: pipeline tag 2, i2s_out
[10:59:07][D][esp-idf:000]: I (229767) AUDIO_PIPELINE: link el->rb, el:0x3d800a30, tag:http, rb:0x3d800f94
[10:59:07][D][esp-idf:000]: I (229769) AUDIO_PIPELINE: link el->rb, el:0x3d800c2c, tag:decoder, rb:0x3d801fd4
[10:59:07][D][esp_adf_pipeline:507]: Setting up event listener.
[10:59:07][D][esp_adf_pipeline:448]: [MediaPlayer] Pipeline changed from INITIALIZING to CREATED. (REQ: 0)
[10:59:07][I][adf_media_player:192]: got new pipeline state: 2, while in MP state IDLE
[10:59:07][D][esp_adf_pipeline:448]: [MediaPlayer] Pipeline changed from CREATED to PREPARING. (REQ: 0)
[10:59:07][I][adf_media_player:192]: got new pipeline state: 3, while in MP state IDLE
[10:59:07][D][adf_i2s_out:141]: Set final i2s settings: 16000
[10:59:07][I][adf_media_player:256]: current mp state: PLAYING
[10:59:07][D][esp_audio_sources:103]: Prepare elements called (initial_call)!
[10:59:07][D][esp_audio_sources:137]: Use fixed settings: no
[10:59:07][D][esp_audio_sources:138]: Streamer status: 1
[10:59:07][D][esp_audio_sources:139]: decoder status: 1
[10:59:07][D][esp_audio_sources:140]: stream uri: http://192.168.0.50:8097/single/media_player.creative_d80_media_player/5a9440b89d4a48a78cda309c7a154632.mp3?ts=1723474747
[10:59:07][D][adf_audio_element:108]: Preparing [http]...
[10:59:07][D][esp-idf:000]: I (229809) AUDIO_THREAD: The http task allocate stack on external memory
[10:59:07][D][esp-idf:000]: I (229810) AUDIO_ELEMENT: [http-0x3d800a30] Element task created
[10:59:07][D][adf_audio_element:108]: Preparing [decoder]...
[10:59:07][D][esp-idf:000]: I (229813) AUDIO_THREAD: The decoder task allocate stack on external memory
[10:59:07][D][esp-idf:000]: I (229815) AUDIO_ELEMENT: [decoder-0x3d800c2c] Element task created
[10:59:07][D][adf_audio_element:108]: Preparing [i2s_out]...
[10:59:07][D][esp-idf:000]: I (229820) AUDIO_ELEMENT: [i2s_out-0x3d800dfc] Element task created
[10:59:07][D][adf_audio_element:165]: Resuming [http]...
[10:59:07][D][adf_audio_element:172]: [http] Sending resume command.
[10:59:07][D][adf_audio_element:165]: Resuming [decoder]...
[10:59:07][D][adf_audio_element:172]: [decoder] Sending resume command.
[10:59:07][D][esp-idf:000][decoder]: I (229859) AUDIO_ELEMENT: [decoder] AEL_MSG_CMD_RESUME,state:1
[10:59:08][D][esp-idf:000][decoder]: I (229861) MP3_DECODER: MP3 opened
[10:59:08][D][adf_audio_element:191]: [http] Checking State, got 72
[10:59:08][D][adf_audio_element:191]: [decoder] Checking State, got 72
[10:59:13][E][esp_adf_pipeline:246]: Timeout while PREPARING. Stopping pipeline!
[10:59:13][D][esp_adf_pipeline:448]: [MediaPlayer] Pipeline changed from PREPARING to ABORTING. (REQ: 1)
[10:59:13][I][adf_media_player:192]: got new pipeline state: 10, while in MP state PLAYING
[10:59:13][I][adf_media_player:256]: current mp state: PLAYING
[10:59:13][I][adf_media_player:257]: anouncement: false
[10:59:13][I][adf_media_player:258]: play_intent: false
[10:59:13][I][adf_media_player:259]: current_uri_: yes
[10:59:13][D][adf_audio_element:324]: [http] Checking State for stopping, got 2
[10:59:13][D][adf_audio_element:324]: [decoder] Checking State for stopping, got 2
[10:59:13][D][esp-idf:000]: E (235825) AUDIO_ELEMENT: [decoder] Element already stopped
[10:59:19][E][esp_adf_pipeline:246]: Timeout while STOPPING. Stopping pipeline!
[10:59:19][D][esp_adf_pipeline:448]: [MediaPlayer] Pipeline changed from ABORTING to DESTROYING. (REQ: 4)
[10:59:19][I][adf_media_player:192]: got new pipeline state: 11, while in MP state PLAYING
[10:59:19][I][adf_media_player:256]: current mp state: PLAYING
[10:59:19][I][adf_media_player:257]: anouncement: false
[10:59:19][I][adf_media_player:258]: play_intent: false
[10:59:19][I][adf_media_player:259]: current_uri_: yes
[10:59:19][D][esp_adf_pipeline:518]: Called deinit_all
[10:59:21][D][esp-idf:000]: W (243843) AUDIO_ELEMENT: [http-0x3d800a30] Element task destroy timeout[2000]
[10:59:21][D][esp-idf:000]: I (243845) AUDIO_PIPELINE: audio_pipeline_unlinked
INFO Successful handshake with creative-d80 @ 192.168.107.145 in 0.056s
More logs with it connected directly to the PC.
[11:13:28]ESP-ROM:esp32s3-20210327
[11:13:28]Build:Mar 27 2021
[11:13:28]rst:0x1 (POWERON),boot:0x8 (SPI_FAST_FLASH_BOOT)
[11:13:28]SPIWP:0xee
[11:13:28]mode:DIO, clock div:1
[11:13:28]load:0x3fce3808,len:0x43c
[11:13:28]load:0x403c9700,len:0xbec
[11:13:28]load:0x403cc700,len:0x2a3c
[11:13:28]entry 0x403c98d8
[11:14:12]E (51202) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
[11:14:12]E (51202) task_wdt: - loopTask (CPU 1)
[11:14:12]E (51202) task_wdt: Tasks currently running:
[11:14:12]E (51202) task_wdt: CPU 0: IDLE
[11:14:12]E (51202) task_wdt: CPU 1: IDLE
[11:14:12]E (51202) task_wdt: Aborting.
[11:14:12]
[11:14:13]abort() was called at PC 0x4203e738 on core 0
[11:14:13]
[11:14:13]
[11:14:13]Backtrace:0x40377afa:0x3fc961800x4037d301:0x3fc961a0 0x40383129:0x3fc961c0 0x4203e738:0x3fc96240 0x40378e35:0x3fc96260 0x420ca3cf:0x3fcf4e40 0x4203ef91:0x3fcf4e60 0x4037e880:0x3fcf4e80
[11:14:13]
[11:14:13]
[11:14:13]
[11:14:13]
[11:14:13]ELF file SHA256: 0000000000000000
[11:14:13]
[11:14:13]Rebooting...
[11:14:13]�ESP-ROM:esp32s3-20210327
[11:14:13]Build:Mar 27 2021
[11:14:13]rst:0xc (RTC_SW_CPU_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
[11:14:13]Saved PC:0x40377704
[11:14:13]SPIWP:0xee
[11:14:13]mode:DIO, clock div:1
[11:14:13]load:0x3fce3808,len:0x43c
[11:14:13]load:0x403c9700,len:0xbec
[11:14:13]load:0x403cc700,len:0x2a3c
[11:14:13]entry 0x403c98d8
Do.you use music assistant? I find using that is the only way to get some stuff to play. Its due to a setting the music assistant uses its in the speaker settings. Enforce lossy mp3 or something like that.
Just note I learned from KevinA that you can still use HA to directly send stuff to ESPHome without MA you just have to go about it a little bit different.
Click Settings → Devices → ESPHome → [YourESPHomeDevice] → then click your Voice Assistant Speaker
