S3VC h265 4k Cam giving me issues
Good morning…
I already have a couple S3VC cams in use and they are awesome.
Now i added a new puppy to the fleet and she is giving me a hard time to set up.
She is my first h265 camera, so maybe the culprit is this “feature”
Here first my subset of errors i am getting:
2024-12-02 05:00:27
frigate.video
coop3_cam: Unable to read frames from ffmpeg process.
error
2024-12-02 05:00:27
frigate.video
coop3_cam: ffmpeg process is not running. exiting capture thread...
error
2024-12-02 05:00:35
watchdog.coop3_cam
Ffmpeg process crashed unexpectedly for coop3_cam.
error
2024-12-02 05:00:35
watchdog.coop3_cam
The following ffmpeg logs include the last 100 lines prior to exit.
error
2024-12-02 05:00:35
ffmpeg.coop3_cam.detect
[AVHWDeviceContext @ 0x5570e00146c0] libva: /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so init failed
error
2024-12-02 05:00:35
[hevc @ 0x5570e0111300] No support for codec hevc profile 1.
error
2024-12-02 05:00:35
[hevc @ 0x5570e0111300] Failed setup for format vaapi: hwaccel initialisation returned error.
error
2024-12-02 05:00:35
Impossible to convert between the formats supported by the filter 'Parsed_fps_0' and the filter 'auto_scale_0'
error
2024-12-02 05:00:35
Error reinitializing filters!
error
2024-12-02 05:00:35
Failed to inject frame into filter network: Function not implemented
error
2024-12-02 05:00:35
Error while processing the decoded data for stream #0:0
and here the code out of my configuration about it:
ffmpeg:
  hwaccel_args: preset-vaapi
    rtsp_coop3_cam:
      - rtsp://user:[email protected]/11
    rtsp_coop3_cam_sub:
      - rtsp://user:[email protected]/12
  coop3_cam:
    ffmpeg:
      inputs:
  #      # High Resolution Stream
        - path: rtsp://127.0.0.1:8554/rtsp_coop3_cam
          roles:
            - record
  #      # Low Resolution Stream
        - path: rtsp://127.0.0.1:8554/rtsp_coop3_cam_sub
          roles:
            - detect
    detect:
      width: 1080
      height: 720
      fps: 5
#    objects:
#      track:
#      - bird
#      filters:
#        person:
#          min_area: 5000
#          max_area: 100000
#          threshold: 0.7
    snapshots:
      enabled: true
      timestamp: true
      bounding_box: true
      retain:
        default: 3
    record:
      sync_recordings: true
      enabled: true
      retain:
        days: 3
        mode: motion
      events:
        retain:
          default: 30
          mode: motion
#    motion:
#      mask:
#      - 1280,0,1280,720,883,720,949,0
Via vlc player i can see the stream when i use the rtsp links, the ip one and the restream…
My hardware is a lenovo tiny with an i3 and an intel gpu and the machine has a usb tensor card.
I am open to any ideas…and thx upfront
Problem is your hardware does not support h265 decoding, you’ll have to disable hwaccel for that camera
Hello…
Thx for the quick answer…
So the stupid i3 internal graphic is messing that up?
At which cpu level would that be supported? Do yu know that of hand?
And how do i disable that for a single camera?
Thx for any more intel…
I believe UHD 600 does
set
hwaccel_args: []
under the ffmpeg of the camera
Good day again…
I was wondering if you can tell in which part/docker of home assistsnt i would need install the non free intel driver for the grpahics acceleration.
I was digging around, and supposingly, the included UHD 630 is able to do h265 but not with the typical used driver and is asking for a “non free” variant.
