Just wanted to say huge thanks to everyone in this thread that brought this info to the table. Maybe one day this can actually make it’s way into the Core release…
Got an S7 Maxv Ultra too, experienced the same…the roborock integration via HACS does a lot but for controlling the mop I still have to use the Xiaomi Mihome app. So +1
I’m considering a new request for controlling the onboard CAM which is currently only available via the Roborock app. Imagine that you want to check out a specific spot in the house which isn’t covered by camera’s, then you’re able to point the spot and have the roborock have a picture or livestream to make sure everything is OK. But thats another request.
Hi, i found workaround. In Node Red is node, or two, dedicated to Roborock. There You can steer moping function. Because i know how to change moping/vacuum settings in node red but have no success to force Roborock clean desired zone, I’ve decided to connect HA automation with Node Red. When button is pushed Node Red sets desired mopping force (amount of water) and vacuum force, then starts HA native automation with desired zone.
Just discovered this thread, I’m using a Q7 Max and node red to individually clean rooms using custom alexa commands, zigbee buttons or whatever. Thanks to the help of the members here I now can control the mop water flow for when I want to clean the kitchen or bathroom.
I’ve got a Roborock Q Revo and the above vacuum.send_command doesn’t work for this type. The Q Revo is integrated through the Roborock integration (no HACS) and I can send the app_segment_clean like in the documentation and ‘Rocky’ starts to brush the mop for action. But that’s not what I want. I want to only vacuum the floor and mop whenever I want that. Can’t figure out how to fix this…
are these values still valid? I have been using these settings for some time, but recently realized I cannot turn off vacuum and do a mopping cycle only. maybe something changed in the firmware or the integration?
Hi @febo7011, I hope you don’t mind if I summarise the information in your post here (I will provide a link back). I’ve spent some time trying to piece together all the required info to get Roborock commands working (to the same level as the app) from Node-RED and your post is a good chunk of the clues required.
Unfortunately, Roborock integration requires Roborock account. I had no issues with that, but one day they have removed S7 Pro Ultra from few regions (or at all), so it stopped working, and S7 Pro Ultra cannot be added again to Roborock app, only to Mi home. So now I have to reimplement everything which perfectly was working for me couple years before. Would never buy Roborock again. I can understand if some model is not supported in some regions. But when it was supported and later removed…
