Cee
(Si Gray)
July 24, 2018, 10:44pm
1
Hiya Wonderful people. I was wondering if anyone can help me out with a Rest sensor at all.
I am using one to pull up my recent SabNZBD downloads,
- platform: rest
resource: http://192.168.2.1:8080/sabnzbd/api?output=json&apikey=redacted&mode=history&start=START&limit=10
method: GET
value_template: '{{ value_json.history.slots[0].name }}'
but I would like to try and strip down the end of the filename and remove the parts I dont need so it sits better in HA. The results I get are something like,
Linux.ISO.debian-9.0.0-amd64-xfce-CD-1
Would it be possible to say removed everything after something like “-xfce*” so it would just leave, `Linux.ISO.debian-9.0.0-amd64.
Is there some kind of template to remove everything after a set value of X, like everything after “-amd64*”
Many thanks in advance.
matty87a
(Matty87a)
July 25, 2018, 11:18am
2
you could look at switching to a command line sensor and piping the curl output through sed.
As per your example, the sed command would be along the lines of
sed -e 's/\-xfce.*//'
Which returns the ouptut:
With the full command for the command line sensor looking like:
command curl 2>/dev/null http://192.168.2.1:8080/sabnzbd/api?output=json&apikey=redacted&mode=history&start=START&limit=10 | sed -e 's/\-xfce.*//'
But if the downloads are gonna be all sorts of different file names, you could find yourself in regex hell quite quickly.
Cee
(Si Gray)
July 25, 2018, 11:57am
3
Thank you for the reply @matty87a .
Tried your code out,
- platform: command_line
command: "command curl 2>/dev/null http://192.168.2.1:8080/sabnzbd/api?output=json&apikey=<redacted>&mode=history&start=START&limit=10 | sed -e 's/\-xfce.*//'"
but it seems to be throwing up an error, looks like the API key isn’t getting passed through in the curl command I think.
pi@hassbian:~ $ command curl 2>/dev/null http://192.168.2.1:8080/sabnzbd/api?output=json&apikey=<redacted>&mode=history&start=START&limit=10 | sed -e 's/\-xfce.*//'
[1] 12334
[2] 12335
[3] 12336
[4] 12338
[2] Done apikey=<redacted>
[3]- Done mode=history
[4]+ Done start=START
pi@hassbian:~ $ {"status": false, "error": "API Key Required"}pi@hassbian:~ $ {"status": false, "error": "API Key Required"}
and then I have to control C to get out of it.
Dont suppose you have an idea’s at all.
matty87a
(Matty87a)
July 25, 2018, 12:10pm
4
Worked for me using my own API key so im not sure.
you may also need to employ grep to isolate the slots currently downloading when using just a curl:
$ curl 2>/dev/null "http://127.0.0.1:8080/api?mode=queue&output=json&apikey=2faacb89addxxxxxxx0c540804ae4af&mode=history&start=START&limit=10" | jq . | grep filename
"filename": "Download.mkv",
(n.b - jq is used purely to tidy up the json)
