Safe Assumptions? (SmartThings, ZWave, etc)
Howdy, folks.
I’m still in search of a smart lock and garage door openers to expand my current home and was wondering if, in general, it’s safe to assume that if any given product is SmartThings or Zwave or Alexa compatible that it will work with HA. There are growing choices in hardware out there and it’s sometimes hard to figure out.
Given the expanding choices of ‘smart-this’ and ‘smart-that’ in the home center stores, it’s hard to know what works, and what doesn’t.
Thanks in advance!
Zwave will always be HA compatible
Smartthings has a cloud based HA integration
Alexa compatible does not mean HA compatible.
Good Evening, and thank you for your reply. :wink:
For those products that are Google-ized, Amazon’ed, or Smart-Thing’ed, is there a way to use them without having to go through their servers? I’m always keen on privacy issues.
Depends on the device. If the device has a HA integration, check its webpage on Integrations - Home Assistant , in the corner you will find its IOT class, e.g.
afbeelding
You want the ones with ‘local’
