Hi there,
Currently I run two VM’s on my server: A -> Apache reverse proxy server and B-> homeassistant.
In the proxy server a subdomain is routed to B, so i’m able to visit my homeassistant with a subdomain.
But when a login fails, the notification in home assistant shows only the IP adress of A instead of the ‘real’ visitor.
I’ve found documentation from the http component, but it is not clear to my how to combine the right parameters like (use_x_forwarded_for, trusted_proxies, trusted_networks) to get a save configuration.
Can someone shows his configuration to get this work? Maybe we can this add to the documentation
Kind regards,
AJ
