Following on from many posts on this topic, I saw the following suggestion: Remote Shutdown/Restart/Sleep/Hibernate PC - #52 by kbirger
So I figured I’d document exactly how to do this:
Part 1: Setup the User
Create a new user.
Create a group
HASSgroupespecially for them, add add the user:
Login as this new user to create home directories etc…
Remove the Hass-User from the
Usersgroup so they cannot log in normally. -
Give this HASSGroup permission to restart:
Note that removing groups doesn’t seem to take effect immediately. Not sure how to fix this.
Part 2: Setup OpenSSH
- Install openSSH Server: Instructions here: Get started with OpenSSH Server for Windows | Microsoft Learn
- Restrict SSH access to just the new user, by adding
AllowGroups HASSgroup. Find the openSSH Server config file%programdata%\ssh\sshd_configand add the line:AllowGroups HASSgroup.
Here’s my config:
PubkeyAuthentication no
PasswordAuthentication no
#If you need to debug:
#SyslogFacility LOCAL0
#LogLevel Debug3
Match Group HASSgroup
AuthorizedKeysFile .ssh\authorized_keys
PubkeyAuthentication yes
- Restart the OpenSSH service. While you’re here, also set it to automatically restart:
- Verify you cannot login using your regular user, but you can with the new user. You can do this by running
ssh localhost/ssh HASS-User@localhost - Generate a key on the home assistant box, and put the public key in the users’s
.ssh\authorized_keysfile.
Part 3: Setup the command
- Add this to the config.yaml:
shell_command:
sleep_pc: ssh -i /config/.ssh/idpub -o 'StrictHostKeyChecking=no' [email protected] 'rundll32.exe powrprof.dll, SetSuspendState Sleep'
