I don’t know what I’m doing wrong. I followed all the steps for the SAJ converter, but I cannot connect it.
Logger: pysaj
Source: components/saj/sensor.py:92
First occurred: 12:11:20 (62 occurrences)
Last logged: 15:10:36
Connection to SAJ inverter is not possible. The inverter may be offline due to darkness. Otherwise check host/ip address.
Dear all,
anyone know if tis integration can work with M2-2.25K-S4. Since o bought this inverter i naver got successfuly to integrate it to HA.
Anyone here know any workaround to integrate it?
Did anybody find a solution for this issue with SAJ? I installed this converter about 18 months ago and used the elekeeper app. I found the IP address of the WiFi module but connecting via a browser does not work. Connections are refused by the converter. I just started with home assistant so would love to be able to use this SAJ integration
