Ok, here’s the complete file:
"""PySAJ interacts as a library to communicate with SAJ inverters"""
import aiohttp
import asyncio
import concurrent
import csv
from io import StringIO
from datetime import date
import logging
import xml.etree.ElementTree as ET
_LOGGER = logging.getLogger(__name__)
MAPPER_STATES = {
"0": "Not connected",
"1": "Waiting",
"2": "Normal",
"3": "Error",
"4": "Upgrading",
URL_PATH_ETHERNET = "real_time_data.xml"
URL_PATH_ETHERNET_INFO = "equipment_data.xml"
URL_PATH_WIFI = "status/status.php"
URL_PATH_WIFI_INFO = "info.php"
class Sensor(object):
"""Sensor definition"""
def __init__(self, key, csv_1_key, csv_2_key, factor, name, unit='',
per_day_basis=False, per_total_basis=False):
self.key = key
self.csv_1_key = csv_1_key
self.csv_2_key = csv_2_key
self.factor = factor
self.name = name
self.unit = unit
self.value = None
self.per_day_basis = per_day_basis
self.per_total_basis = per_total_basis
self.date = date.today()
self.enabled = False
class Sensors(object):
"""SAJ sensors"""
def __init__(self, wifi=False):
self.__s = []
self.add(
Sensor("p-ac", 11, 23, "", "current_power", "W"),
Sensor("e-today", 3, 3, "/100", "today_yield", "kWh", True),
Sensor("e-total", 1, 1, "/100", "total_yield", "kWh", False,
True),
Sensor("t-today", 4, 4, "/10", "today_time", "h", True),
Sensor("t-total", 2, 2, "/10", "total_time", "h", False, True),
Sensor("CO2", 21, 33, "/10", "total_co2_reduced", "kg", False,
True),
Sensor("temp", 20, 32, "/10", "temperature", "°C"),
Sensor("state", 22, 34, "", "state"),
Sensor("maxPower", -1, -1, "", "today_max_current", "W", True)
def __len__(self):
"""Length."""
return len(self.__s)
def __contains__(self, key):
"""Get a sensor using either the name or key."""
try:
if self[key]:
return True
except KeyError:
return False
def __getitem__(self, key):
for sen in self.__s:
if sen.name == key or sen.key == key:
return sen
raise KeyError(key)
def __iter__(self):
"""Iterator."""
return self.__s.__iter__()
def add(self, sensor):
"""Add a sensor, warning if it exists."""
if isinstance(sensor, (list, tuple)):
for sss in sensor:
self.add(sss)
return
if not isinstance(sensor, Sensor):
raise TypeError("pysaj.Sensor expected")
if sensor.name in self:
old = self[sensor.name]
self.__s.remove(old)
_LOGGER.warning("Replacing sensor %s with %s", old, sensor)
if sensor.key in self:
_LOGGER.warning("Duplicate SAJ sensor key %s", sensor.key)
self.__s.append(sensor)
class SAJ(object):
"""Provides access to SAJ inverter data"""
def __init__(self, host, wifi=False, username='admin', password='admin'):
self.host = host
self.wifi = wifi
self.username = username
self.password = password
self.serialnumber = "XXXXXXXXXXXXXXXXX"
self.url = "http://{0}/".format(self.host)
if self.wifi:
if (len(self.username) > 0
and len(self.password) > 0):
self.url = "http://{0}:{1}@{2}/".format(self.username,
self.password,
self.host)
self.url_info = self.url + URL_PATH_WIFI_INFO
self.url += URL_PATH_WIFI
else:
self.url_info = self.url + URL_PATH_ETHERNET_INFO
self.url += URL_PATH_ETHERNET
async def read(self, sensors):
"""Returns necessary sensors from SAJ inverter"""
try:
timeout = aiohttp.ClientTimeout(total=5)
async with aiohttp.ClientSession(timeout=timeout,
raise_for_status=True) as session:
current_url = self.url_info
async with session.get(current_url) as response:
data = await response.text()
if self.wifi:
csv_data = StringIO(data)
reader = csv.reader(csv_data)
for row in reader:
self.serialnumber = row.pop(0)
else:
xml = ET.fromstring(data)
find = xml.find("SN")
if find is not None:
self.serialnumber = find.text
_LOGGER.debug("Inverter SN: %s", self.serialnumber)
at_least_one_enabled = False
if self.wifi:
ncol = len(next(reader))
csv_data.seek(0)
values = []
for row in reader:
for (i, v) in enumerate(row):
values.append(v)
for sen in sensors:
if ncol < 24:
if sen.csv_1_key != -1:
try:
v = values[sen.csv_1_key]
except IndexError:
v = None
else:
v = None
else:
if sen.csv_2_key != -1:
try:
v = values[sen.csv_2_key]
except IndexError:
v = None
else:
v = None
if v is not None:
if sen.name == "state":
sen.value = MAPPER_STATES[v]
else:
sen.value = eval(
"{0}{1}".format(v, sen.factor)
sen.date = date.today()
sen.enabled = True
at_least_one_enabled = True
else:
for sen in sensors:
find = xml.find(sen.key)
sen.value = find.text
sen.enabled = True
if not at_least_one_enabled:
if self.wifi:
raise csv.Error
else:
raise ET.ParseError
if sen.enabled:
_LOGGER.debug("Got new value for sensor %s: %s",
sen.name, sen.value)
return True
except (aiohttp.client_exceptions.ClientConnectorError, asyncio.exceptions.TimeoutError,
concurrent.futures._base.TimeoutError):
# Connection to inverter not possible.
# This can be "normal" - so warning instead of error - as SAJ
# inverters are powered by DC and thus have no power after the sun
# has set.
_LOGGER.warning("Connection to SAJ inverter is not possible. " +
"The inverter may be offline due to darkness. " +
"Otherwise check host/ip address.")
return False
except aiohttp.client_exceptions.ClientResponseError as err:
# 401 Unauthorized: wrong username/password
if err.status == 401:
raise UnauthorizedException(err)
else:
raise UnexpectedResponseException(err)
except csv.Error:
# CSV is not valid
str.format("No valid CSV received from {0} at {1}", self.host,
current_url)
except ET.ParseError:
# XML is not valid or even no XML at all
str.format("No valid XML received from {0} at {1}", self.host,
current_url)
class UnauthorizedException(Exception):
"""Exception for Unauthorized 401 status code"""
def __init__(self, message):
Exception.__init__(self, message)
class UnexpectedResponseException(Exception):
"""Exception for unexpected status code"""
