I just got the Salus KL08RF with the CO10RF zigbee coordinator. How would you go about to integrate that setup into HA. Would I need to buy the UGE600 gateway first? Would is it that can be controlled afterwards in HA? Can I for example change the temperature settings?
@tinko You should check if this is supported by ZHA by googling “ZHA supported devices” and looking it up. If it is, then you need to know how you tell each device to join the network so you can add them. However, I’m not sure how this will work. My guess is that the KL08RF just has a whole bunch of on/off switches for each zone and the thermostats just have a temperature and send out an on/off signal. So if you brought it all into HA you might have to manually send the thermostat signals to the KL08RF. But to figure that out you would have to read the manual.
-David
