I wanted to check on my configuration and had older Samba instaled that gave errors.
I updated to 0.8 and still it doesn’t start. I have hass.io 0.42, HC 0.8, HA 0.48.1.
Tried to uninstall, reinstall and restart of server.
Running on RPi3 over WiFi.
starting version 3.2.2
smbd version 4.6.4 started.
Copyright Andrew Tridgell and the Samba Team 1992-2017
Registered MSG_REQ_POOL_USAGE
Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED
Processing section "[config]"
Processing section "[addons]"
Processing section "[share]"
Processing section "[backup]"
added interface eth0 ip=172.17.0.4 bcast=172.17.255.255 netmask=255.255.0.0
INFO: Profiling support unavailable in this build.
No builtin backend found, trying to load plugin
Module 'tdbsam' loaded
tdb(/var/lib/samba/registry.tdb): tdb_open_ex: could not open file /var/lib/samba/registry.tdb: No such file or directory
tdb(/var/lib/samba/account_policy.tdb): tdb_open_ex: could not open file /var/lib/samba/account_policy.tdb: No such file or directory
account_policy_get: tdb_fetch_uint32_t failed for type 1 (min password length), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 2 (password history), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 3 (user must logon to change password), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 4 (maximum password age), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 5 (minimum password age), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 6 (lockout duration), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 7 (reset count minutes), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 8 (bad lockout attempt), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 9 (disconnect time), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 10 (refuse machine password change), returning 0
tdbsam_open: Converting version 0.0 database to version 4.0.
tdbsam_convert_backup: updated /var/lib/samba/private/passdb.tdb file.
tdb(/var/lib/samba/winbindd_idmap.tdb): tdb_open_ex: could not open file /var/lib/samba/winbindd_idmap.tdb: No such file or directory
STATUS=daemon 'smbd' finished starting up and ready to serve connections
waiting for connections
