I want to have the Date in the samba backup Name ({Type} Backup {Date}) in the following form:
dd-mm-yyyy. Who can help me.
Mans thanks
Günter
Mans thanks
Günter
I dont know, how to do that and if I can give you a little practical suggestion, I would not even do that.
Like it is default, yyyy-mm-dd, when you have a lot of backups i a directory and you are viewing it in alphabetical order, the backups would be still sorted exactly in a time-lapse.
The way you want it, it becomes a unsorted mess.
Hi BebeMicha,
Thanks for your quick help. How can I elimine the time? That is Not necessário for me.
Change
in
Name {Type} Backup
This is Not What I meant. I mean, to eliminate the time part in the Date. I Would like to have yyyy-mm-dd instead of yyyy-mm-dd hh:mm.
This would be the process. You would have to use a combination of listing the files to get the full name string into a text file, then do a concatenate on the of each item in the file removing the end portion of the string (time element). Then use that result in a rename of the file.
Thank you for your answer. But I have no clue how to do that.
or edit this file on lines 19 and 27:
Many thanks. It Works.
No, I’m just somehow extremely good with searching the web. Don’t ask Google, ask me…
