Samba and default Home Assistant shared folders
I am confused, but that is normal.
The PC command net view \\NUC shows all of the default Home Assistant shared folders on my Intel NUC computer.
C:\Users\steve>net view \\nuc
Shared resources at \\nuc
Samba Home Assistant
Share name  Type  Used as  Comment
addons      Disk
backup      Disk
config      Disk
media       Disk
share       Disk
ssl         Disk
The command completed successfully.
But, only the config share will map to a drive letter in the PC using net use. (The config folder is the only default folder that is also shared in my smb.conf file.) All of the other Home Assistant default directories return an error: The network name cannot be found.
The command smbtree shows all of the folders on my host shared in smb.conf.
They all map to a drive letter on the PC using net use.
steve@NUC:/$ smbtree
MSHOME
        \\NUC                           NUC server (Samba, Ubuntu)
                \\NUC\Artisan-1430      EPSON Artisan 1430
                \\NUC\IPC$              IPC Service (NUC server (Samba, Ubuntu))
                \\NUC\mntD              SATA drive on NUC
                \\NUC\snapshots         Home Assistant Snapshots folder
                \\NUC\steve             Shared folder on Steve
                \\NUC\config            Home Assistant config folder
                \\NUC\nuc               Nuc/ folder
                \\NUC\print$            Printer Drivers
So, here’s my confusion. Why does the PC command net view show all of the Home Assistant default directories, but I can’t see them in File Explorer?
Hi Steve,
I am not an expert, but in the documentation of the add on it shows these are the folders that are shared:
This addon exposes the following directories over smb (samba):
Directory Description
addons This is for your local add-ons.
backup This is for your snapshots.
config This is for your Home Assistant configuration.
media This is for local media files.
share This is for your data that is shared between add-ons and Home Assistant.
ssl This is for your SSL certificates.
Thanks for the feedback.
The PC command net view shows all of the Home Assistant default directories, so they are exposed to SMB. But why can’t I see them in File Explorer, or net use?
Samba on the PC is running fine as I can see and map other folders on my
Intel NUC computer that are in my smb.conf file.
Do I need to add the Home Assistant Default Directories to my smb.conf file as well?
The SMB shares work, but I think what you might be dealing with is an old windows problem when when you connect to one share on an SMB system that other shares pop this message. It’s been a while since I had to deal with it myself, but I know it used to be a problem and you had to disconnect all the SMB shares and then reboot and try again and there might be a registry change too.
I’ve definitely had this problem with Windows to SMB before, and I have read a forum post elsewhere in the recent past regarding this still happening in Windows 10.
This makes sense. It didn’t occur to me (but it should have) that it is a Windows problem.
The issue seems to be random. (I hate the way that Windows does networking. For example I can’t net use to the same server, different folders, with the same hostname).
After installing your samba share, windows side show system error 67 has occurred, the network name cannot be found. If I use the old samba share, the network is ok. Please help.
Is any official mention of these folders anywhere?
Documentation. Is here: addons/DOCS.md at 55fd0cb8ba90bdcaca3162e02c0ebdc176f50703 · home-assistant/addons · GitHub
So, it sounds like you’re trying to to gain access to the other folders and not just the config folder in your FIle Explorer:
  • Go to your File Explorer
  • RIght Click on ‘Network’
  • Click on ‘Map Network Drive…’
  • Click on ‘Connect to a Web site that you can use…’ listed in blue for me as the bottom line of the dialogue box
  • Click Next
  • Click Next (in regard to ‘Choose a custom network location’)
  • Type in the name of your Home Assistant IP using the following:
  • \192.168.x.x\share
  • Click Next
Done!
I realize that this is an old question for you, but in case you haven’t been able to do this, or for anyone else who may desire an answer to this question.
