SAMBA BACKUP has stopped backing up my installed addons -- SOLVED!
It seems the Supervisor 2022.6.1 and later has changed to the point that Samba Backup no longer selects the installed addons to add to the backup
I believe it has to do with this line from main.sh
addons=$(ha addons --raw-json | jq -rc '.data.addons[] | select (.installed == true) | .slug')
I believe ‘ha addons’ now only returns the installed addons which made the installed:true redundant in the json
see this for details
Still working for me:
Untitled
I suggest you also ask what your issue is in the Samba backup topic.
Did you create an issue in the addon repo?
Yes I did
Supervisor 2022.6.1 seems to break the backing up of AddOns · Issue #89 · thomasmauerer/hassio-addons (github.com)
but is seems the author hasnt made any changes since February
are you on Supervisor 2022.6.1 or later… (still in beta) I mention it now as some people may not want to update to Supervisor 2022.6.1 until there is a fix
I’m on 2022.6.2
I am too …
if you go into terminal and type ha addons --raw-json the installed:true is no longer a key pair so the select above prevents it from returning any addons
it still runs
but it only gets the folders and Homeassistant config - with no error
but no addons
Though that only happened this afternoon. If 2022.6.1 is still in beta as well I would not have been on it when my backup ran last night. I only enabled beta updates this morning.
Probably explains it.
Will see what happens tonight.
Fwiw everything you’re showing makes sense. Think you did find a bug and the root cause. You can submit a PR to fix it, pretty simple just remove the select bit from that statement, like this:
addons=$(ha addons --raw-json | jq -rc '.data.addons[] | .slug')
But there’s two other PRs open for a while and I don’t see any updates since last September so I’m not sure the author is maintaining it anymore. Might have to fork it and fix it there or make it into a local addon.
Not really a github user per se … I use a fork to eat with… :slight_smile: and when it comes to docker… ummm not so much either…
PR created:
But yeah Thomas seems to have been MIA for a few months.
I’m still here… :grinning: thanks for mentioning that breaking change and for the PR. I’ll take a look at it this weekend. But I guess I have to wait until Supervisor 2022.06.XX is officially released before I can publish an update.
Good point. Proposed a suggestion on the PR that I think will work before and after the update.
I posted this message because I was afraid someone would upgrade and their backups would not be complete as there was no indication that it didnt backup everything I was expecting… I only noticed because on my test/dev box it was only taking 1 minute to complete… no error and if it had gone on for more than 7 days … no real backups left
Thanks for an Awsome addon though it has worked flawlessly till this happened… :slight_smile:
Confirmed. No addons in last nights backup.
Issue is fixed in v5.1.0. You can update even if you’re running a supervisor version below 2022.06.
I can confirm … the 5.1.0 version has solved my issue for 2022.6+ version of Supervisor and it is working on my Production Server ( Supervisor 2022.5.3 ) as well…(it just takes about an hour to backup… but I can see its getting the addons in the log…
Thanks Thomas Mauerer!
It has been 8 hours and I’m not seeing the addon update?
I had it automatically announced today :wink:
Are you running 2022.7.0b2?
