I have installed the samba add-on in my Home assistant Raspberry pi setup. But the Home assistant directories do not show-up in my Windows Explorer. ( The network discovery is activated on the Windows Machine)
type \\ipofyourpi\cong
into your explorer navigation bar.
For example \\192.168.1.2\config
That will take you directly to the directory. Sometimes network discovery can be flaky. Navigate that way or map the to have a permanent link in place.
It worked perfectly
