I want to open my hassio folder on my windows computer ,but the folder don’t show up. I am using virtual box for hosting Homme Assistant can you help me.
Good luck.
Log
[INFO] Read hostname: hassio Registered MSG_REQ_POOL_USAGE Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED No builtin backend found, trying to load plugin tdbsam_open: Converting version 0.0 database to version 4.0. tdbsam_convert_backup: updated /var/lib/samba/private/passdb.tdb file. tdb(/var/lib/samba/winbindd_idmap.tdb): tdb_open_ex: could not open file /var/lib/samba/winbindd_idmap.tdb: No such file or directory tdb(/var/lib/samba/account_policy.tdb): tdb_open_ex: could not open file /var/lib/samba/account_policy.tdb: No such file or directory account_policy_get: tdb_fetch_uint32_t failed for type 1 (min password length), returning 0 account_policy_get: tdb_fetch_uint32_t failed for type 2 (password history), returning 0 account_policy_get: tdb_fetch_uint32_t failed for type 3 (user must logon to change password), returning 0 account_policy_get: tdb_fetch_uint32_t failed for type 4 (maximum password age), returning 0 account_policy_get: tdb_fetch_uint32_t failed for type 5 (minimum password age), returning 0 account_policy_get: tdb_fetch_uint32_t failed for type 6 (lockout duration), returning 0 account_policy_get: tdb_fetch_uint32_t failed for type 7 (reset count minutes), returning 0 account_policy_get: tdb_fetch_uint32_t failed for type 8 (bad lockout attempt), returning 0 account_policy_get: tdb_fetch_uint32_t failed for type 9 (disconnect time), returning 0 account_policy_get: tdb_fetch_uint32_t failed for type 10 (refuse machine password change), returning 0 Added user hassio. nmbd version 4.8.4 started. Copyright Andrew Tridgell and the Samba Team 1992-2018 Registered MSG_REQ_POOL_USAGE Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED added interface docker0 ip=172.17.0.1 bcast=172.17.255.255 netmask=255.255.0.0 added interface hassio ip=172.30.32.1 bcast=172.30.33.255 netmask=255.255.254.0 added interface enp0s3 ip=192.168.0.27 bcast=192.168.0.255 netmask=255.255.255.0 making subnet name:192.168.0.27 Broadcast address:192.168.0.255 Subnet mask:255.255.255.0 making subnet name:172.30.32.1 Broadcast address:172.30.33.255 Subnet mask:255.255.254.0 making subnet name:172.17.0.1 Broadcast address:172.17.255.255 Subnet mask:255.255.0.0 making subnet name:UNICAST_SUBNET Broadcast address:0.0.0.0 Subnet mask:0.0.0.0 making subnet name:REMOTE_BROADCAST_SUBNET Broadcast address:0.0.0.0 Subnet mask:0.0.0.0 load_lmhosts_file: Can’t open lmhosts file /etc/samba/lmhosts. Error was No such file or directory daemon_ready: STATUS=daemon ‘nmbd’ finished starting up and ready to serve connections smbd version 4.8.4 started. Copyright Andrew Tridgell and the Samba Team 1992-2018 Registered MSG_REQ_POOL_USAGE Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED Processing section “[config]” Processing section “[addons]” Processing section “[ssl]” Processing section “[share]” Processing section “[backup]” added interface docker0 ip=172.17.0.1 bcast=172.17.255.255 netmask=255.255.0.0 added interface hassio ip=172.30.32.1 bcast=172.30.33.255 netmask=255.255.254.0 added interface enp0s3 ip=192.168.0.27 bcast=192.168.0.255 netmask=255.255.255.0 INFO: Profiling support unavailable in this build. No builtin backend found, trying to load plugin tdb(/var/lib/samba/registry.tdb): tdb_open_ex: could not open file /var/lib/samba/registry.tdb: No such file or directory daemon_ready: STATUS=daemon ‘smbd’ finished starting up and ready to serve connections waiting for connections check_for_master_browser_fail: Forcing election on workgroup WORKGROUP subnet 172.17.0.1 check_for_master_browser_fail: Forcing election on workgroup WORKGROUP subnet 172.30.32.1 send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 172.17.0.1 send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 172.30.32.1 send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 172.17.0.1 send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 172.30.32.1 send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 172.17.0.1 send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 172.30.32.1 send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 172.17.0.1 send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 172.30.32.1 send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 172.17.0.1 run_elections: >>> Won election for workgroup WORKGROUP on subnet 172.17.0.1 <<< become_local_master_browser: Starting to become a master browser for workgroup WORKGROUP on subnet 172.17.0.1 send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 172.30.32.1 run_elections: >>> Won election for workgroup WORKGROUP on subnet 172.30.32.1 <<< become_local_master_browser: Starting to become a master browser for workgroup WORKGROUP on subnet 172.30.32.1 ***** Samba name server HASSIO is now a local master browser for workgroup WORKGROUP on subnet 172.17.0.1 ***** ***** Samba name server HASSIO is now a local master browser for workgroup WORKGROUP on subnet 172.30.32.1 *****
