Hi, two days I am struggling with the Samba Share addon, and still not work. I tryed connect to server with address in file explorer \\192.168.100.103\config but nothing happened. Already tryed change 128bit to 40-56bit encryption with same result. Samba v1 is manualy installed on Win 10.
Hardware
Raspberry Pi 4 Model B 2GB
PC - Windows 10 Pro 1909
HassOS
- version: 3.12 - 32 bit
- deployment: production
- hostname: homeassistant
Home Assistant
- version: 0.106.5
Samba Share
- version - 9.0
- samba config:
workgroup: HOME
username: Suggorath
password: hass
interface: ''
allow_hosts:
- 10.0.0.0/8
- 172.16.0.0/12
- 192.168.0.0/16
veto_files:
- ._*
- .DS_Store
- Thumbs.db
- icon?
- .Trashes
Note: Already tryed âinterface: eth0â without success.
- samba log:
[21:30:42] INFO: Hostname: homeassistant
Registered MSG_REQ_POOL_USAGE
Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED
No builtin backend found, trying to load plugin
tdbsam_open: Converting version 0.0 database to version 4.0.
tdbsam_convert_backup: updated /var/lib/samba/private/passdb.tdb file.
tdb(/var/lib/samba/winbindd_idmap.tdb): tdb_open_ex: could not open file /var/lib/samba/winbindd_idmap.tdb: No such file or directory
tdb(/var/lib/samba/account_policy.tdb): tdb_open_ex: could not open file /var/lib/samba/account_policy.tdb: No such file or directory
account_policy_get: tdb_fetch_uint32_t failed for type 1 (min password length), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 2 (password history), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 3 (user must logon to change password), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 4 (maximum password age), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 5 (minimum password age), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 6 (lockout duration), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 7 (reset count minutes), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 8 (bad lockout attempt), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 9 (disconnect time), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 10 (refuse machine password change), returning 0
Added user Suggorath.
nmbd version 4.10.8 started.
Copyright Andrew Tridgell and the Samba Team 1992-2019
added interface docker0 ip=172.17.0.1 bcast=172.17.255.255 netmask=255.255.0.0
added interface hassio ip=172.30.32.1 bcast=172.30.33.255 netmask=255.255.254.0
added interface eth0 ip=192.168.100.103 bcast=192.168.100.255 netmask=255.255.255.0
making subnet name:192.168.100.103 Broadcast address:192.168.100.255 Subnet mask:255.255.255.0
making subnet name:172.30.32.1 Broadcast address:172.30.33.255 Subnet mask:255.255.254.0
making subnet name:172.17.0.1 Broadcast address:172.17.255.255 Subnet mask:255.255.0.0
making subnet name:UNICAST_SUBNET Broadcast address:0.0.0.0 Subnet mask:0.0.0.0
making subnet name:REMOTE_BROADCAST_SUBNET Broadcast address:0.0.0.0 Subnet mask:0.0.0.0
load_lmhosts_file: Can't open lmhosts file /etc/samba/lmhosts. Error was No such file or directory
daemon_ready: daemon 'nmbd' finished starting up and ready to serve connections
smbd version 4.10.8 started.
Processing section "[config]"
Processing section "[addons]"
Processing section "[ssl]"
Processing section "[share]"
Processing section "[backup]"
INFO: Profiling support unavailable in this build.
tdb(/var/lib/samba/registry.tdb): tdb_open_ex: could not open file /var/lib/samba/registry.tdb: No such file or directory
daemon_ready: daemon 'smbd' finished starting up and ready to serve connections
waiting for connections
check_for_master_browser_fail: Forcing election on workgroup HOME subnet 172.17.0.1
check_for_master_browser_fail: Forcing election on workgroup HOME subnet 172.30.32.1
check_for_master_browser_fail: Forcing election on workgroup HOME subnet 192.168.100.103
send_election_dgram: Sending election packet for workgroup HOME on subnet 172.17.0.1
send_election_dgram: Sending election packet for workgroup HOME on subnet 172.30.32.1
send_election_dgram: Sending election packet for workgroup HOME on subnet 192.168.100.103
run_elections: >>> Won election for workgroup HOME on subnet 172.17.0.1 <<<
become_local_master_browser: Starting to become a master browser for workgroup HOME on subnet 172.17.0.1
run_elections: >>> Won election for workgroup HOME on subnet 172.30.32.1 <<<
become_local_master_browser: Starting to become a master browser for workgroup HOME on subnet 172.30.32.1
run_elections: >>> Won election for workgroup HOME on subnet 192.168.100.103 <<<
become_local_master_browser: Starting to become a master browser for workgroup HOME on subnet 192.168.100.103
System log:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[19:34:03] INFO: Update udev informations
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
20-03-10 19:34:06 INFO (MainThread) [__main__] Initialize Supervisor setup
20-03-10 19:34:06 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attach to Supervisor homeassistant/armv7-hassio-supervisor with version 209
20-03-10 19:34:07 INFO (MainThread) [__main__] Setup Supervisor
20-03-10 19:34:07 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
20-03-10 19:34:07 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
20-03-10 19:34:07 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: de.pengutronix.rauc - /
20-03-10 19:34:07 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.NetworkManager - /org/freedesktop/NetworkManager/DnsManager
20-03-10 19:34:07 INFO (MainThread) [supervisor.host.info] Update local host information
20-03-10 19:34:07 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-03-10 19:34:07 INFO (MainThread) [supervisor.host.services] Update service information
20-03-10 19:34:07 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-10 19:34:07 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-03-10 19:34:07 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-03-10 19:34:07 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-03-10 19:34:07 INFO (MainThread) [supervisor.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
20-03-10 19:34:07 INFO (MainThread) [supervisor.host.services] Reload local service hassos-apparmor.service
20-03-10 19:34:07 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
20-03-10 19:34:07 INFO (SyncWorker_1) [supervisor.docker.interface] Attach to homeassistant/armv7-hassio-dns with version 1
20-03-10 19:34:07 INFO (SyncWorker_2) [supervisor.docker.interface] Attach to homeassistant/armv7-hassio-audio with version 8
20-03-10 19:34:07 INFO (MainThread) [supervisor.misc.forwarder] Start DNS port forwarding to 172.30.32.3
20-03-10 19:34:07 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-10 19:34:07 INFO (MainThread) [supervisor.audio] Start Audio plugin
20-03-10 19:34:07 INFO (SyncWorker_2) [supervisor.docker.interface] Clean hassio_audio application
20-03-10 19:34:07 INFO (SyncWorker_4) [supervisor.docker.interface] Clean hassio_dns application
20-03-10 19:34:09 INFO (SyncWorker_4) [supervisor.docker.dns] Start DNS homeassistant/armv7-hassio-dns with version 1 - 172.30.32.3
20-03-10 19:34:09 INFO (SyncWorker_2) [supervisor.docker.audio] Start Audio homeassistant/armv7-hassio-audio with version 8 - 172.30.32.4
20-03-10 19:34:09 INFO (SyncWorker_1) [supervisor.docker.interface] Attach to homeassistant/raspberrypi4-homeassistant with version 0.106.5
20-03-10 19:34:09 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /
20-03-10 19:34:09 INFO (MainThread) [supervisor.hassos] Detect HassOS 3.12 / BootSlot A
20-03-10 19:34:09 INFO (SyncWorker_0) [supervisor.docker.hassos_cli] Found HassOS CLI homeassistant/armv7-hassio-cli with version 21
20-03-10 19:34:10 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/a0d7b954 repository
20-03-10 19:34:10 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/core repository
20-03-10 19:34:10 INFO (MainThread) [supervisor.store] Load add-ons from store: 64 all - 64 new - 0 remove
20-03-10 19:34:10 INFO (MainThread) [supervisor.addons] Found 2 installed add-ons
20-03-10 19:34:10 INFO (SyncWorker_4) [supervisor.docker.interface] Attach to homeassistant/armv7-addon-configurator with version 4.7
20-03-10 19:34:10 INFO (SyncWorker_9) [supervisor.docker.interface] Attach to homeassistant/armv7-addon-samba with version 9.0
20-03-10 19:34:10 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-10 19:34:10 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
20-03-10 19:34:10 INFO (MainThread) [supervisor.discovery] Load 0 messages
20-03-10 19:34:10 INFO (MainThread) [supervisor.ingress] Load 2 ingress session
20-03-10 19:34:10 INFO (MainThread) [supervisor.secrets] Load Home Assistant secrets: 1
20-03-10 19:34:10 INFO (MainThread) [__main__] Run Supervisor
20-03-10 19:34:10 INFO (MainThread) [supervisor.api] Start API on 172.30.32.2
20-03-10 19:34:10 INFO (MainThread) [supervisor.utils.gdbus] Call de.pengutronix.rauc.Installer.Mark on /
20-03-10 19:34:10 INFO (MainThread) [supervisor.hassos] Rauc: A - marked slot kernel.0 as good
20-03-10 19:34:10 INFO (MainThread) [supervisor.addons] Phase 'initialize' start 0 add-ons
20-03-10 19:34:10 INFO (MainThread) [supervisor.addons] Phase 'system' start 0 add-ons
20-03-10 19:34:10 INFO (MainThread) [supervisor.addons] Phase 'services' start 1 add-ons
20-03-10 19:34:11 INFO (SyncWorker_12) [supervisor.docker.addon] Start Docker add-on homeassistant/armv7-addon-samba with version 9.0
20-03-10 19:34:16 INFO (SyncWorker_15) [supervisor.docker.interface] Start homeassistant/raspberrypi4-homeassistant
20-03-10 19:35:15 INFO (MainThread) [supervisor.homeassistant] Detect a running Home Assistant instance
20-03-10 19:35:15 INFO (MainThread) [supervisor.addons] Phase 'application' start 1 add-ons
20-03-10 19:35:16 INFO (SyncWorker_3) [supervisor.docker.addon] Start Docker add-on homeassistant/armv7-addon-configurator with version 4.7
20-03-10 19:35:21 INFO (MainThread) [supervisor.tasks] All core tasks are scheduled
20-03-10 19:35:21 INFO (MainThread) [supervisor.hwmon] Started Supervisor hardware monitor
20-03-10 19:35:21 INFO (MainThread) [supervisor.core] Supervisor is up and running
20-03-10 19:35:21 INFO (MainThread) [supervisor.host.info] Update local host information
20-03-10 19:35:21 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-03-10 19:35:21 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-10 19:35:22 INFO (MainThread) [supervisor.host.services] Update service information
20-03-10 19:35:22 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-10 19:35:22 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-03-10 19:35:22 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-03-10 19:35:22 INFO (MainThread) [supervisor.host.sound] Update PulseAudio informationSystem log
