Samba not working
I’m using the Samba Share plug-in. I am running HA on RPi3B+. I’m now on version 0.106.4.
I’m not certain when this last worked, but it had worked previously for me. I haven’t changed any settings. The only change other than the occasional updating of the HA version is that work upgraded my laptop from Windows 7 to Windows 10.
Here’s the log from when I start the plug-in:
[21:01:10] INFO: Hostname: hassio
Registered MSG_REQ_POOL_USAGE
Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED
No builtin backend found, trying to load plugin
tdbsam_open: Converting version 0.0 database to version 4.0.
tdbsam_convert_backup: updated /var/lib/samba/private/passdb.tdb file.
tdb(/var/lib/samba/winbindd_idmap.tdb): tdb_open_ex: could not open file /var/lib/samba/winbindd_idmap.tdb: No such file or directory
tdb(/var/lib/samba/account_policy.tdb): tdb_open_ex: could not open file /var/lib/samba/account_policy.tdb: No such file or directory
account_policy_get: tdb_fetch_uint32_t failed for type 1 (min password length), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 2 (password history), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 3 (user must logon to change password), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 4 (maximum password age), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 5 (minimum password age), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 6 (lockout duration), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 7 (reset count minutes), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 8 (bad lockout attempt), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 9 (disconnect time), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 10 (refuse machine password change), returning 0
Added user hassio.
nmbd version 4.10.8 started.
Copyright Andrew Tridgell and the Samba Team 1992-2019
smbd version 4.10.8 started.
Processing section "[config]"
Processing section "[addons]"
Processing section "[ssl]"
Processing section "[share]"
Processing section "[backup]"
added interface docker0 ip=172.17.0.1 bcast=172.17.255.255 netmask=255.255.0.0
added interface hassio ip=172.30.32.1 bcast=172.30.33.255 netmask=255.255.254.0
added interface eth0 ip=192.168.86.36 bcast=192.168.86.255 netmask=255.255.255.0
making subnet name:192.168.86.36 Broadcast address:192.168.86.255 Subnet mask:255.255.255.0
making subnet name:172.30.32.1 Broadcast address:172.30.33.255 Subnet mask:255.255.254.0
INFO: Profiling support unavailable in this build.
making subnet name:172.17.0.1 Broadcast address:172.17.255.255 Subnet mask:255.255.0.0
making subnet name:UNICAST_SUBNET Broadcast address:0.0.0.0 Subnet mask:0.0.0.0
making subnet name:REMOTE_BROADCAST_SUBNET Broadcast address:0.0.0.0 Subnet mask:0.0.0.0
load_lmhosts_file: Can't open lmhosts file /etc/samba/lmhosts. Error was No such file or directory
daemon_ready: daemon 'nmbd' finished starting up and ready to serve connections
tdb(/var/lib/samba/registry.tdb): tdb_open_ex: could not open file /var/lib/samba/registry.tdb: No such file or directory
daemon_ready: daemon 'smbd' finished starting up and ready to serve connections
waiting for connections
check_for_master_browser_fail: Forcing election on workgroup WORKGROUP subnet 172.17.0.1
check_for_master_browser_fail: Forcing election on workgroup WORKGROUP subnet 172.30.32.1
check_for_master_browser_fail: Forcing election on workgroup WORKGROUP subnet 192.168.86.36
send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 172.17.0.1
send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 172.30.32.1
send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 192.168.86.36
run_elections: >>> Won election for workgroup WORKGROUP on subnet 172.17.0.1 <<<
become_local_master_browser: Starting to become a master browser for workgroup WORKGROUP on subnet 172.17.0.1
run_elections: >>> Won election for workgroup WORKGROUP on subnet 172.30.32.1 <<<
become_local_master_browser: Starting to become a master browser for workgroup WORKGROUP on subnet 172.30.32.1
run_elections: >>> Won election for workgroup WORKGROUP on subnet 192.168.86.36 <<<
become_local_master_browser: Starting to become a master browser for workgroup WORKGROUP on subnet 192.168.86.36
Samba name server HASSIO is now a local master browser for workgroup WORKGROUP on subnet 172.17.0.1
Samba name server HASSIO is now a local master browser for workgroup WORKGROUP on subnet 172.30.32.1
Samba name server HASSIO is now a local master browser for workgroup WORKGROUP on subnet 192.168.86.36
Here’s my config for the plug-in:
workgroup: WORKGROUP
username: hassio
password: samba
interface: ''
allow_hosts:
  - 10.0.0.0/8
  - 172.16.0.0/12
  - 192.168.0.0/16
  - 192.168.10.0/24
veto_files:
  - ._*
  - .DS_Store
  - Thumbs.db
  - icon?
  - .Trashes
I added that last host address after searching the message boards on this topic.
Any advice you have is appreciated.
that is covered by 192.168.0.0/16
Maybe try this How to access files on network devices using SMBv1 on Windows 10 | Windows Central
EDIT: It’s probably not that. I disabled SMB1 on my Win10 computer and it still connects fine to HA shares. (My old Stora NAS… not so much lol)
Is your new windows 10 install a member of WORKGROUP?
I don’t think it creates them by default after v1803.
It also appears to be complaining about the insufficient length and complexity of your password.
I don’t even know what Workgroup is! I just used this default setting, as it previously worked that way.
But then you upgraded and the new operating system does not function the same way ‘out of the box’.
EDIT: actually it was HomeGroup file sharing that got dropped. Still, check that your computer is a member of the workgroup.
DavidFW1960 adding the SMB1 (clicking the checkbox) now allows my computer to recognize and connect. I additionally lengthened my password. Next, I unchecked the SMB1 box and kept the complex password, then restarted the computer, but the computer again wouldn’t recognize my home assistant.
So, I think that solved the problem. Thanks!
