Hello guys!
I’ve been running Hassio on my pi2 for a few days just to experiment what’s coming! Previously I had Hassbian installed which by default shares the config via samba. It was working and showing up perfectly on my Macs in Finder
However Hassio Samba Share add-on seems to not work for me and I can’t really find out why. This is what the log shows
starting version 3.2.1
smbd version 4.5.10 started.
Copyright Andrew Tridgell and the Samba Team 1992-2016
Registered MSG_REQ_POOL_USAGE
Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED
Processing section "[config]"
Processing section "[addons]"
Processing section "[share]"
added interface eth0 ip=172.17.0.3 bcast=172.17.255.255 netmask=255.255.0.0
INFO: Profiling support unavailable in this build.
No builtin backend found, trying to load plugin
Module 'tdbsam' loaded
tdb(/var/lib/samba/registry.tdb): tdb_open_ex: could not open file /var/lib/samba/registry.tdb: No such file or directory
tdb(/var/lib/samba/account_policy.tdb): tdb_open_ex: could not open file /var/lib/samba/account_policy.tdb: No such file or directory
account_policy_get: tdb_fetch_uint32_t failed for type 1 (min password length), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 2 (password history), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 3 (user must logon to change password), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 4 (maximum password age), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 5 (minimum password age), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 6 (lockout duration), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 7 (reset count minutes), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 8 (bad lockout attempt), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 9 (disconnect time), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 10 (refuse machine password change), returning 0
tdbsam_open: Converting version 0.0 database to version 4.0.
tdbsam_convert_backup: updated /var/lib/samba/private/passdb.tdb file.
tdb(/var/lib/samba/winbindd_idmap.tdb): tdb_open_ex: could not open file /var/lib/samba/winbindd_idmap.tdb: No such file or directory
STATUS=daemon 'smbd' finished starting up and ready to serve connections
waiting for connections
It seems to be running correctly, however I’ve tried restarting the PI, reinstalling the add-on, etc with no luck. Also in the logs there’s a reference to eth0 ip=172.17.0.3
which I guess it’s something internal of the samba add-on? Because my real hassio ip is 10.0.1.9!
In case it helps, here’s my current version of everything! Thanks!
