Samba share 1
I can’t setup samba. In the home assistant, they are probably lit green. But I can’t find anything in Win 11. I’ve tried enabling everything I could find anywhere on the internet, but it still doesn’t work. What could be the problem.
Web 10.0.0.136 odmítl připojení.
Zkuste:
Zkontrolovat připojení
Zkontrolovat proxy server a firewall
ERR_CONNECTION_REFUSED
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/samba.sh
[18:08:46] INFO: Hostname: homeassistant
[18:08:46] INFO: Interfaces: eth0
No builtin backend found, trying to load plugin
tdbsam_open: Converting version 0.0 database to version 4.0.
tdbsam_convert_backup: updated /var/lib/samba/private/passdb.tdb file.
account_policy_get: tdb_fetch_uint32_t failed for type 1 (min password length), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 2 (password history), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 3 (user must logon to change password), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 4 (maximum password age), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 5 (minimum password age), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 6 (lockout duration), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 7 (reset count minutes), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 8 (bad lockout attempt), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 9 (disconnect time), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 10 (refuse machine password change), returning 0
Added user RSvorcik.
cont-init: info: /etc/cont-init.d/samba.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun nmbd (no readiness notification)
services-up: info: copying legacy longrun smbd (no readiness notification)
added interface eth0 ip=2001:1ae9:10:9500:c00f:b868:8024:df7a bcast= netmask=ffff:ffff:ffff:ffff::
added interface eth0 ip=10.0.0.136 bcast=10.0.0.255 netmask=255.255.255.0
nmbd version 4.16.10 started.
Copyright Andrew Tridgell and the Samba Team 1992-2022
Registered MSG_REQ_POOL_USAGE
Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED
making subnet name:10.0.0.136 Broadcast address:10.0.0.255 Subnet mask:255.255.255.0
create_subnets: ignoring non IPv4 interface.
making subnet name:UNICAST_SUBNET Broadcast address:0.0.0.0 Subnet mask:0.0.0.0
making subnet name:REMOTE_BROADCAST_SUBNET Broadcast address:0.0.0.0 Subnet mask:0.0.0.0
smbd version 4.16.10 started.
uid=0 gid=0 euid=0 egid=0
Processing section “[config]”
Processing section “[addons]”
Processing section “[ssl]”
Processing section “[share]”
Processing section “[backup]”
Processing section “[media]”
INFO: Profiling support unavailable in this build.
waiting for connections
s6-rc: info: service legacy-services successfully started
check_for_master_browser_fail: Forcing election on workgroup WORKGROUP subnet 10.0.0.136
send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 10.0.0.136
run_elections: >>> Won election for workgroup WORKGROUP on subnet 10.0.0.136 <<<
become_local_master_browser: Starting to become a master browser for workgroup WORKGROUP on subnet 10.0.0.136
You haven’t specified what you have tried, below is not a “specification” it’s only leave it to the reader to imagine/speculating about what you are doing
Home assistant I have Hyper-V on Win 11. I installed everything according to the instructions above. I logged in on Win 10.0.0.136 . In Win 11 I enabled sharing in multiple locations, SMB. It doesn’t work anyway. I don’t know if something else needs to be installed in Win?
READ the Pic
I’m a beginner, I think I’ve done everything described in the picture. I also watched the samba installation video.
then go to the add-on site ( i think where you installed the samba, and configured it, read the documentation, about how to configure it, if you already have configured it, then read howto connect to the shares, from your windows ( as in the bottom of the pic ( the pic is a screenshot from the samba add-on page)
I understand you are a beginner, but you will keep having alot problems, if you refuse to read, i therefore also post the same link as you ones have been “recommended to read” in your first Topic
PLEASE read the whole document
Thanks for the direction
