I had a problem (SD card error maybe?) last night after creating a snapshot and then trying to restart home assistant. I reflashed the SD Card, reinstalling HASSIO. When my Raspberry Pi finished setting everything back up I, installed Samba Share, copied in a backup snapshot and pressed Restore Selected (meant to do "Wipe & Restore but hit the wrong one). Everything seemed to set up right, but when I went to access the files using Samba, it isn’t working. I can still see hassio in Networks in Finder, but can’t access it. Pressing Connect As brings up this error:
In the Hassio tab, the Samba add-on refuses to start, and in the logs I can see this error showing up, a lot:
ERROR (SyncWorker_7) [hassio.docker] Can't start addon_core_samba: 403 Client Error: Forbidden ("endpoint with name addon_core_samba already exists in network host")
I tried doing Wipe & Install with the snapshot, thinking maybe it was because I just pressed restore before, but it’s still not working.
Does anyone know how to fix this? Do I need to reflash the drive again, and start over?
