Samba share add worked fine until a few days ago, but it doesn’t start. username and password are already set up correctly.
error
[12:58:52] ERROR: Something went wrong contacting the API
[12:58:55] FATAL: Setting a username and password is required!
s6-rc: warning: unable to start service init-smbd: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-smbd: starting
This is probably going to be hard for anyone here to diagnose because you would need to share your actual config, but since that contains your username and password it’s not only ill advised to do that but I’m sure you just simply wouldn’t want to do it.
What you might try is simplifying your username and password as much as you can, removing special characters and see if it’s a complexity issue. I don’t know why it would work one day an stop the next unless an update was applied either to HA Samba implementation or to the other computer.
The message is clearly bombing on the user/pass, something somewhere must have changed if it worked before.
my username is all lowercase with no spaces and my password is a mix of numbers, upper and lower case alphabet with no spaces either.
Let me try with this username and password combination.
[02:49:47] FATAL: Setting a username and password is required!
