Just did a fresh install of Hassio on a Rpi. I installed Samba share 9.2.0. There is no place to edit or save the configuration. I believe there used to be a dialog box where you could edit the configuration and then save it. I don’t see that any longer. There is just the instructions to edit the file.
In the supervisor page for samba, look at the top of the page - there are now three tabs - Info, Configuration and Logs.
Ha! When did they sneak that in? It does that for all addons it seems…
0,109 or 0.108 i think.
0.109.something anyway… I did a screen shot for someone showing settings a day or so ago and it wasn’t there then…
Well it is probably a supervisor rather than core feature, so I suppose we should talk in those terms. Perhaps 220.
Thank you. I should have looked a little closer.
You’re most probably right… supervisor…
