hi I´m using hassio on pi, suddenly I cound´t reach my directory through my computer anymore, tried to update the samba share, even reinstall and nothing, here´s my configuration:
justa check my supervisor logs and is showing this:
18-11-25 14:26:14 WARNING (SyncWorker_6) [hassio.docker.interface] Can't grep logs from homeassistant/armhf-addon-samba: 500 Server Error: Internal Server Error ("can not get logs from container which is dead or marked for removal")
18-11-25 14:26:16 INFO (SyncWorker_9) [hassio.docker.interface] Clean homeassistant/armhf-addon-samba Docker application
18-11-25 14:26:16 ERROR (SyncWorker_9) [hassio.docker] Can't create container from addon_core_samba: 409 Client Error: Conflict ("Conflict. The container name "/addon_core_samba" is already in use by container "a4b5eefeebe19641bd72958c47580b0c557143113c1b3908a6cc60404faa5339". You have to remove (or rename) that container to be able to reuse that name.")
18-11-25 14:26:22 WARNING (SyncWorker_16) [hassio.docker.interface] Can't grep logs from homeassistant/armhf-addon-samba: 500 Server Error: Internal Server Error ("can not get logs from container which is dead or marked for removal")
